Agilex 7 R-Tile RES FPGA – CXL Device Enumeration Failure with CXL IP Design Example
OPN:DK-DEV-AGI027RES (Power Solution 1)
SN: AGIPCIE8000296
1.Failure Symptom
The CXL device fails to enumerate when using the CXL Type-3 IP design example.
• lspci -vvv | grep 0ddb does not detect the CXL device
• numactl -H does not report a CXL NUMA node
The issue persists across multiple system reboots and bitstream rebuilds. A factory reset was attempted but did not resolve the issue.
2. When did the failure happen? When did you buy the part, and when did you receive it?
The device was received approximately two years ago.
The failure was observed during initial bring-up and has been present since first use
3. How did you discover the failure? Please describe it in detail.
We programmed the FPGA with the CXL Type-3 design example; however, the host server failed to enumerate the device.
The same bitstream works correctly on other Agilex FPGA boards, indicating the issue is specific to this unit
4. In which part of your process did you find the issue (Lab, production, quality, etc.)?
Lab environment.
4.1 Was the device already in the field? How many times has it been used?
No. The device has only been used in a controlled lab environment for bring-up and testing
5. How many units failed and how many units were used/tested by you? Which is the production code?
• Failed units: 1
• Units tested: Multiple Agilex FPGA boards
• Production code: Not available
Only this unit exhibits the failure.
6. How did you determine the failure? Please elaborate on the procedures.
Multiple bring-up attempts were performed using known-good hardware, software, and bitstreams.
• 6.1 Internal Debug: No internal physical failure analysis (e.g., X-ray or short-circuit testing) was performed.
• 6.2 Device Swap: Yes. Replacing the board with a known-good FPGA resolves the issue.
7. Was the failing unit ever working before the failure?
No. The unit has never functioned correctly since initial use.
8. How did you rule out electrical overstress (EOS) or electrostatic discharge (ESD)?
There is no visible physical damage on the FPGA or PCB.
The board has been handled according to standard ESD-safe lab procedures.
9. What are your expectations from this failure analysis?
Identify the root cause of the failure and either restore proper CXL IP functionality or provide a replacement device
10. Have you re-balled your device? If yes, was it lead-free reballing?
No. The device has not been re-balled, and no third-party rework has been performed.
11. Please add pictures of the device from the top and the bottom.See attached.
12. Is there any other relevant information that could assist in the failure analysis?
No additional information at this time.
- RongY_altera
Contributor
What's the Quartus version you're using?
Please use Q23.4 Pro onwards.
Rong
- nskim
Hi Rong,
We have tried Quartus Pro 24.3 and 24.1, both newer than 23.4. The CXL design example fails to bring up the device on both Quartus versions.- RongY_altera
Contributor
You may need to put two DDR4-2666 DIMM memory onto the dev kit.
Rong
- RongY_altera
Contributor
Q24.1 is not able to generate the ED for your target OPN. The Agilex 7 I-series dev kit has different memory arrangement for power solution 1 dev kit and power solution 2 dev kit.
Please provide me your qsf and constraints/qsf_device_pinout.tcl. Thanks.
What's the original Quartus version you used for generating the example?
Rong
- nskim
Hi Rong,
Thanks for the explanation. I believe the OPN mismatch is the root cause. Do you have an example design for the DK-DEV-AGI027RES, or know which Quartus version includes one? Our available versions (23.3–25.1) do not include a design example for this board. I’ve attached the QSF and TCL files we are currently using for reference.
# (C) 2001-2024 Intel Corporation. All rights reserved.
# Your use of Intel Corporation's design tools, logic functions and other
# software and tools, and its AMPP partner logic functions, and any output
# files from any of the foregoing (including device programming or simulation
# files), and any associated documentation or information are expressly subject
# to the terms and conditions of the Intel Program License Subscription
# Agreement, Intel FPGA IP License Agreement, or other applicable
# license agreement, including, without limitation, that your use is for the
# sole purpose of programming logic devices manufactured by Intel and sold by
# Intel or its authorized distributors. Please refer to the applicable
# agreement for further details.
set_global_assignment -name TOP_LEVEL_ENTITY cxltyp3_memexp_ddr4_top
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 23.3.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "02:50:54 JUNE 02, 2022"
set_global_assignment -name LAST_QUARTUS_VERSION "24.3.0 Pro Edition"
set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files
set_global_assignment -name FAMILY "Agilex 7"
set_global_assignment -name DEVICE AGIB027R29A1E2VR3
set_global_assignment -name FLOW_DISABLE_ASSEMBLER OFF
set_global_assignment -name NUM_PARALLEL_PROCESSORS 16
set_global_assignment -name GENERATE_COMPRESSED_SOF ON
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "100 KHZ"
set_global_assignment -name USE_CONF_DONE SDM_IO16
set_global_assignment -name USE_PWRMGT_SCL SDM_IO0
set_global_assignment -name USE_PWRMGT_SDA SDM_IO12
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "LINEAR FORMAT"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE OTHER
set_global_assignment -name PWRMGT_LINEAR_FORMAT_N "-13"
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS 47
set_global_assignment -name PWRMGT_SLAVE_DEVICE1_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE2_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE3_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE4_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE5_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE6_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE7_ADDRESS 00
set_global_assignment -name PWRMGT_DIRECT_FORMAT_COEFFICIENT_M 1
set_global_assignment -name PWRMGT_TRANSLATED_VOLTAGE_VALUE_UNIT VOLTS
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE OFF
set_global_assignment -name STRATIXV_CONFIGURATION_SCHEME "AVST X8"
set_global_assignment -name MINIMUM_SEU_INTERVAL 10000
set_global_assignment -name ACTIVE_SERIAL_CLOCK AS_FREQ_115MHZ_IOSC
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1
source ./constraints/cxltyp3ddr_quartus_constraints_ed_en.tcl
source ./constraints/qsf_device_pinout.tcl
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_compliance/cxl_compliance_csr_avmm_slave.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_compliance/cxl_compliance_csr_top.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_pio_parameters.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_avalon_sc_fifo_1931_vhmcgqy.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_avalon_st_pipeline_stage_1920_zterisq.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_burst_adapter_1922_tsepz7q.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_burst_adapter_altera_avalon_st_pipeline_stage_1922_pev47ty.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_demultiplexer_1921_s5kn7vi.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_master_agent_191_mpbm6tq.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_master_translator_191_g7h47bq.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_multiplexer_1921_5zcdh2i.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_multiplexer_1921_zxmqgaq.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_router_1921_6kkcoeq.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_router_1921_sv2vwxi.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_slave_agent_191_ncfkfri.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_merlin_slave_translator_191_x56fcki.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_altera_mm_interconnect_1920_sx2feoa.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_MEM0.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_MEM0_altera_avalon_onchip_memory2_1932_vi4l4uq.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_reset_sync.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_std_synchronizer_nocut.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_avmm_intf.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_avst_intf.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_cpl.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_fifos.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_rw.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_sch_intf.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_pio.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_aer.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_bam_v2_crdt_intf.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_default_config.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_pf_checker.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_pcie_bam_v2_hwtcl.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed_pio0.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/pcie_ed.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_pio_ed_top.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cxl_pio/intel_cxl_tx_crdt_intf.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_ecc_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_channel_adapter.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_cxlmem_ready_control.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_rmw_shim.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_ecc.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_emif.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_devmem_top.sv
set_global_assignment -name IP_FILE ./common/cdc_fifos/fifo_8b_256w_show_ahead.ip
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/axi2avmm_bridge.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/mc_top/mc_top.sv
set_global_assignment -name IP_FILE ./common/cdc_fifos/cfg_to_iosf_fifo_vcd_ED.ip
set_global_assignment -name IP_FILE ./common/cdc_fifos/iosf_to_cfg_fifo_vcd_ED.ip
set_global_assignment -name SYSTEMVERILOG_FILE ./common/afu/afu_top.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/afu/afu_csr_avmm_slave.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/ex_default_csr/ex_default_csr_avmm_slave.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/ex_default_csr/ex_default_csr_top.sv
set_global_assignment -name IP_FILE ./common/mc_top/altecc_enc_dec_ip/altecc_enc_latency0.ip
set_global_assignment -name IP_FILE ./common/mc_top/altecc_enc_dec_ip/altecc_dec_latency1.ip
set_global_assignment -name IP_FILE ./common/mc_top/altecc_enc_dec_ip/altecc_dec_latency2.ip
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_pld_if.svh.iv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_fifo_vcd.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_dcfifo_pipe_vcd.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_scfifo_pipe_vcd.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_data_fifos_pipe.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_core_fifos.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_crd_check.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_crd_lmt.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_crd_type.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_data_fifos.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_rx_hdr_data_fifos.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/avst4to1_ss_tlp_hdr_decode.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/cxl_ed_avst_4to1_rx_side.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/avst4to1_rx/ed_define.svh.iv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr0_reg_macros.vh.iv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_reg_macros.vh.iv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_globals.vh.iv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cust_afu/cust_afu_wrapper.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/tmp_cafu_csr0_cfg_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr0_cfg_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr0_cfg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_mem_target_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_alg1a_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_ram_1r1w.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_ram_1r1w_be.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_cdc_fifo_vcd.v
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/fifo_sync_1.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/pattern_expand_by_byte_mask.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/pattern_expand_by_byte_mask_ver2.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/pattern_reduce_by_pattern_size.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/verify_sc_compare.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/verify_sc_extract_error_pattern.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/verify_sc_index_byte_offset.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_calc_error_address.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_execute_write_axi_fsm.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_execute_write.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_execute_response_count.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_verify_sc_read_axi_fsm.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_verify_sc_read.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_verify_sc_response.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_top_level_fsm_sc_only.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/alg_1a_top.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_afu_status_regs.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_config_and_cxl_errors_reg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_config_check.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_debug_logs.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_error_injection_regs.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_poison_injection.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_top_level_fsm.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/mwae_top.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr_doe.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_mem_target.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/csr0_mc_status_glue.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_devreg_mailbox_elog.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_devreg_mailbox.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_reg_router.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_csr_avmm_slave.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/ccv_afu_cdc_fifo.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr0_wrapper.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/cafu_csr0/cafu_csr0_avmm_wrapper.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/axi_to_avst/axi_avst_if_pkg.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/axi_to_avst/axi_to_avst_bridge.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/axi_to_avst/intel_cxl_afu_cache_io_demux.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/axi_to_avst/intel_cxl_afu_pio_mux.sv
set_global_assignment -name SYSTEMVERILOG_FILE ./common/axi_to_avst/intel_cxl_tx_tlp_fifos.sv
set_global_assignment -name IP_FILE ./common/mc_top/emif_ip/emif_cal_two_ch.ip
set_global_assignment -name IP_FILE ./common/mc_top/emif_ip/emif.ip
set_global_assignment -name IP_FILE ./common/mc_top/sip_quartus_ips/rspfifo_IP/rspfifo.ip
set_global_assignment -name IP_FILE ./common/mc_top/sip_quartus_ips/reqfifo_IP/reqfifo.ip
set_global_assignment -name SEARCH_PATH ./common
set_global_assignment -name SEARCH_PATH ./../intel_rtile_cxl_top_cxltyp3_ed/intel_rtile_cxl_top_1140/synth
set_global_assignment -name SEARCH_PATH ./common/avst4to1_rx/
set_global_assignment -name SEARCH_PATH ./common/cafu_csr0/
set_global_assignment -name SEARCH_PATH ./common/axi_to_avst/
set_global_assignment -name QSYS_FILE ./../intel_rtile_cxl_top_cxltyp3_ed.ip
set_global_assignment -name SYSTEMVERILOG_FILE ed_top_wrapper_typ3.sv
set_global_assignment -name QSYS_FILE common/intel_reset_release/intel_reset_release.ip
set_global_assignment -name SYSTEMVERILOG_FILE cxltyp3_memexp_ddr4_top.sv
set_global_assignment -name SDC_FILE ./constraints/cxl_memexp_top.sdc
set_instance_assignment -name VIRTUAL_PIN ON -to phy_sys_ial_* -entity cxltyp3_memexp_ddr4_top
set_instance_assignment -name VIRTUAL_PIN ON -to o_phy_* -entity cxltyp3_memexp_ddr4_top
set_instance_assignment -name VIRTUAL_PIN ON -to i_phy_* -entity cxltyp3_memexp_ddr4_top
## Used for Example design on Devkit RNR-B0##
## Used for Example design on Devkit RNR-A0##
# reset interface for U22 / BANK 15C
set_location_assignment PIN_CY30 -to resetn
set_instance_assignment -name IO_STANDARD "1.0 V" -to resetn
# fabric PLL 1 refclk
#set_location_assignment PIN_LR13 -to refclk4
#set_location_assignment PIN_KU36 -to refclk4
set_location_assignment PIN_AN61 -to refclk4
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to refclk4
# refclk interface for U22 /BANK 15C
set_location_assignment PIN_EG27 -to refclk0
set_instance_assignment -name IO_STANDARD "HCSL" -to refclk0
set_location_assignment PIN_FC27 -to refclk1
set_instance_assignment -name IO_STANDARD "HCSL" -to refclk1
# CXT TX Pin assignments for U22 / BANK 15C
set_location_assignment PIN_AH22 -to cxl_tx_n[0]
set_location_assignment PIN_AU16 -to cxl_tx_n[1]
set_location_assignment PIN_BA22 -to cxl_tx_n[2]
set_location_assignment PIN_BK16 -to cxl_tx_n[3]
set_location_assignment PIN_BN22 -to cxl_tx_n[4]
set_location_assignment PIN_CB16 -to cxl_tx_n[5]
set_location_assignment PIN_CE22 -to cxl_tx_n[6]
set_location_assignment PIN_CP16 -to cxl_tx_n[7]
set_location_assignment PIN_CV22 -to cxl_tx_n[8]
set_location_assignment PIN_DG16 -to cxl_tx_n[9]
set_location_assignment PIN_DK22 -to cxl_tx_n[10]
set_location_assignment PIN_DW16 -to cxl_tx_n[11]
set_location_assignment PIN_EB22 -to cxl_tx_n[12]
set_location_assignment PIN_EM16 -to cxl_tx_n[13]
set_location_assignment PIN_ER22 -to cxl_tx_n[14]
set_location_assignment PIN_FD16 -to cxl_tx_n[15]
set_location_assignment PIN_AL20 -to cxl_tx_p[0]
set_location_assignment PIN_AP14 -to cxl_tx_p[1]
set_location_assignment PIN_BD20 -to cxl_tx_p[2]
set_location_assignment PIN_BG14 -to cxl_tx_p[3]
set_location_assignment PIN_BT20 -to cxl_tx_p[4]
set_location_assignment PIN_BW14 -to cxl_tx_p[5]
set_location_assignment PIN_CH20 -to cxl_tx_p[6]
set_location_assignment PIN_CL14 -to cxl_tx_p[7]
set_location_assignment PIN_DA20 -to cxl_tx_p[8]
set_location_assignment PIN_DD14 -to cxl_tx_p[9]
set_location_assignment PIN_DN20 -to cxl_tx_p[10]
set_location_assignment PIN_DT14 -to cxl_tx_p[11]
set_location_assignment PIN_EE20 -to cxl_tx_p[12]
set_location_assignment PIN_EH14 -to cxl_tx_p[13]
set_location_assignment PIN_EV20 -to cxl_tx_p[14]
set_location_assignment PIN_FA14 -to cxl_tx_p[15]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to cxl_tx_n[*]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to cxl_tx_p[*]
# CXT RX Pin assignments for U22 / BANK 15C
set_location_assignment PIN_AH10 -to cxl_rx_n[0]
set_location_assignment PIN_AU3 -to cxl_rx_n[1]
set_location_assignment PIN_BA10 -to cxl_rx_n[2]
set_location_assignment PIN_BK3 -to cxl_rx_n[3]
set_location_assignment PIN_BN10 -to cxl_rx_n[4]
set_location_assignment PIN_CB3 -to cxl_rx_n[5]
set_location_assignment PIN_CE10 -to cxl_rx_n[6]
set_location_assignment PIN_CP3 -to cxl_rx_n[7]
set_location_assignment PIN_CV10 -to cxl_rx_n[8]
set_location_assignment PIN_DG3 -to cxl_rx_n[9]
set_location_assignment PIN_DK10 -to cxl_rx_n[10]
set_location_assignment PIN_DW3 -to cxl_rx_n[11]
set_location_assignment PIN_EB10 -to cxl_rx_n[12]
set_location_assignment PIN_EM3 -to cxl_rx_n[13]
set_location_assignment PIN_ER10 -to cxl_rx_n[14]
set_location_assignment PIN_FD3 -to cxl_rx_n[15]
set_location_assignment PIN_AL8 -to cxl_rx_p[0]
set_location_assignment PIN_AP1 -to cxl_rx_p[1]
set_location_assignment PIN_BD8 -to cxl_rx_p[2]
set_location_assignment PIN_BG1 -to cxl_rx_p[3]
set_location_assignment PIN_BT8 -to cxl_rx_p[4]
set_location_assignment PIN_BW1 -to cxl_rx_p[5]
set_location_assignment PIN_CH8 -to cxl_rx_p[6]
set_location_assignment PIN_CL1 -to cxl_rx_p[7]
set_location_assignment PIN_DA8 -to cxl_rx_p[8]
set_location_assignment PIN_DD1 -to cxl_rx_p[9]
set_location_assignment PIN_DN8 -to cxl_rx_p[10]
set_location_assignment PIN_DT1 -to cxl_rx_p[11]
set_location_assignment PIN_EE8 -to cxl_rx_p[12]
set_location_assignment PIN_EH1 -to cxl_rx_p[13]
set_location_assignment PIN_EV8 -to cxl_rx_p[14]
set_location_assignment PIN_FA1 -to cxl_rx_p[15]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to cxl_rx_n[*]
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to cxl_rx_p[*]
set_location_assignment PIN_MA44 -to mem_refclk[0]
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to mem_refclk[0] -entity ddr4
set_location_assignment PIN_LH48 -to mem_ck[0][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V SSTL" -to mem_ck[0][0]
set_location_assignment PIN_LL49 -to mem_ck_n[0][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V SSTL" -to mem_ck_n[0][0]
set_location_assignment PIN_LH44 -to mem_bg[0][1]
set_location_assignment PIN_LR47 -to mem_bg[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_bg[0][*]
set_location_assignment PIN_LN48 -to mem_ba[0][1]
set_location_assignment PIN_LW47 -to mem_ba[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_ba[0][*]
set_location_assignment PIN_MA48 -to mem_alert_n[0]
set_location_assignment PIN_LN44 -to mem_oct_rzqin[0]
set_location_assignment PIN_LB48 -to mem_par[0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_par[0]
set_location_assignment PIN_LB46 -to mem_cke[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_cke[0][0]
set_location_assignment PIN_LH46 -to mem_odt[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_odt[0][0]
set_location_assignment PIN_KW45 -to mem_act_n[0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_act_n[0]
set_location_assignment PIN_LB44 -to mem_cs_n[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_cs_n[0][0]
set_location_assignment PIN_LL45 -to mem_reset_n[0]
set_location_assignment PIN_LN46 -to mem_a[0][16]
set_location_assignment PIN_LR45 -to mem_a[0][15]
set_location_assignment PIN_MA46 -to mem_a[0][14]
set_location_assignment PIN_LW45 -to mem_a[0][13]
set_location_assignment PIN_LR43 -to mem_a[0][12]
set_location_assignment PIN_KJ49 -to mem_a[0][11]
set_location_assignment PIN_KF48 -to mem_a[0][10]
set_location_assignment PIN_KU48 -to mem_a[0][9]
set_location_assignment PIN_KR49 -to mem_a[0][8]
set_location_assignment PIN_KJ47 -to mem_a[0][7]
set_location_assignment PIN_KF46 -to mem_a[0][6]
set_location_assignment PIN_KR47 -to mem_a[0][5]
set_location_assignment PIN_KU46 -to mem_a[0][4]
set_location_assignment PIN_KF44 -to mem_a[0][3]
set_location_assignment PIN_KJ45 -to mem_a[0][2]
set_location_assignment PIN_KU44 -to mem_a[0][1]
set_location_assignment PIN_KR45 -to mem_a[0][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_a[0][*]
set_location_assignment PIN_LN60 -to mem_dq[0][71]
set_location_assignment PIN_LR55 -to mem_dq[0][70]
set_location_assignment PIN_LR59 -to mem_dq[0][69]
set_location_assignment PIN_LW55 -to mem_dq[0][68]
set_location_assignment PIN_MA60 -to mem_dq[0][67]
set_location_assignment PIN_LN56 -to mem_dq[0][66]
set_location_assignment PIN_LW59 -to mem_dq[0][65]
set_location_assignment PIN_MA56 -to mem_dq[0][64]
set_location_assignment PIN_MC57 -to mem_dq[0][63]
set_location_assignment PIN_MD52 -to mem_dq[0][62]
set_location_assignment PIN_MK57 -to mem_dq[0][61]
set_location_assignment PIN_MH52 -to mem_dq[0][60]
set_location_assignment PIN_MH56 -to mem_dq[0][59]
set_location_assignment PIN_MC53 -to mem_dq[0][58]
set_location_assignment PIN_MD56 -to mem_dq[0][57]
set_location_assignment PIN_MK53 -to mem_dq[0][56]
set_location_assignment PIN_MC63 -to mem_dq[0][55]
set_location_assignment PIN_MD58 -to mem_dq[0][54]
set_location_assignment PIN_MK63 -to mem_dq[0][53]
set_location_assignment PIN_MH58 -to mem_dq[0][52]
set_location_assignment PIN_MD62 -to mem_dq[0][51]
set_location_assignment PIN_MK59 -to mem_dq[0][50]
set_location_assignment PIN_MH62 -to mem_dq[0][49]
set_location_assignment PIN_MC59 -to mem_dq[0][48]
set_location_assignment PIN_KW55 -to mem_dq[0][47]
set_location_assignment PIN_LB50 -to mem_dq[0][46]
set_location_assignment PIN_LB54 -to mem_dq[0][45]
set_location_assignment PIN_LH50 -to mem_dq[0][44]
set_location_assignment PIN_LH54 -to mem_dq[0][43]
set_location_assignment PIN_KW51 -to mem_dq[0][42]
set_location_assignment PIN_LL55 -to mem_dq[0][41]
set_location_assignment PIN_LL51 -to mem_dq[0][40]
set_location_assignment PIN_LN54 -to mem_dq[0][39]
set_location_assignment PIN_LR49 -to mem_dq[0][38]
set_location_assignment PIN_LR53 -to mem_dq[0][37]
set_location_assignment PIN_LN50 -to mem_dq[0][36]
set_location_assignment PIN_MA54 -to mem_dq[0][35]
set_location_assignment PIN_MA50 -to mem_dq[0][34]
set_location_assignment PIN_LW53 -to mem_dq[0][33]
set_location_assignment PIN_LW49 -to mem_dq[0][32]
set_location_assignment PIN_MC45 -to mem_dq[0][31]
set_location_assignment PIN_MD40 -to mem_dq[0][30]
set_location_assignment PIN_MK45 -to mem_dq[0][29]
set_location_assignment PIN_MH40 -to mem_dq[0][28]
set_location_assignment PIN_MH44 -to mem_dq[0][27]
set_location_assignment PIN_MC41 -to mem_dq[0][26]
set_location_assignment PIN_MD44 -to mem_dq[0][25]
set_location_assignment PIN_MK41 -to mem_dq[0][24]
set_location_assignment PIN_MC51 -to mem_dq[0][23]
set_location_assignment PIN_MD46 -to mem_dq[0][22]
set_location_assignment PIN_MK51 -to mem_dq[0][21]
set_location_assignment PIN_MH46 -to mem_dq[0][20]
set_location_assignment PIN_MD50 -to mem_dq[0][19]
set_location_assignment PIN_MK47 -to mem_dq[0][18]
set_location_assignment PIN_MH50 -to mem_dq[0][17]
set_location_assignment PIN_MC47 -to mem_dq[0][16]
set_location_assignment PIN_LN42 -to mem_dq[0][15]
set_location_assignment PIN_LR37 -to mem_dq[0][14]
set_location_assignment PIN_LR41 -to mem_dq[0][13]
set_location_assignment PIN_LW37 -to mem_dq[0][12]
set_location_assignment PIN_LW41 -to mem_dq[0][11]
set_location_assignment PIN_LN38 -to mem_dq[0][10]
set_location_assignment PIN_MA42 -to mem_dq[0][9]
set_location_assignment PIN_MA38 -to mem_dq[0][8]
set_location_assignment PIN_MC39 -to mem_dq[0][7]
set_location_assignment PIN_MD34 -to mem_dq[0][6]
set_location_assignment PIN_MK39 -to mem_dq[0][5]
set_location_assignment PIN_MH34 -to mem_dq[0][4]
set_location_assignment PIN_MD38 -to mem_dq[0][3]
set_location_assignment PIN_MK35 -to mem_dq[0][2]
set_location_assignment PIN_MH38 -to mem_dq[0][1]
set_location_assignment PIN_MC35 -to mem_dq[0][0]
set_instance_assignment -name IO_STANDARD "1.2-V POD" -to mem_dq[0][*]
set_location_assignment PIN_LW57 -to mem_dqs[0][8]
set_location_assignment PIN_MH54 -to mem_dqs[0][7]
set_location_assignment PIN_MH60 -to mem_dqs[0][6]
set_location_assignment PIN_LH52 -to mem_dqs[0][5]
set_location_assignment PIN_LW51 -to mem_dqs[0][4]
set_location_assignment PIN_MH42 -to mem_dqs[0][3]
set_location_assignment PIN_MH48 -to mem_dqs[0][2]
set_location_assignment PIN_LW39 -to mem_dqs[0][1]
set_location_assignment PIN_MH36 -to mem_dqs[0][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V POD" -to mem_dqs[0][*]
set_location_assignment PIN_MA58 -to mem_dqs_n[0][8]
set_location_assignment PIN_MK55 -to mem_dqs_n[0][7]
set_location_assignment PIN_MK61 -to mem_dqs_n[0][6]
set_location_assignment PIN_LL53 -to mem_dqs_n[0][5]
set_location_assignment PIN_MA52 -to mem_dqs_n[0][4]
set_location_assignment PIN_MK43 -to mem_dqs_n[0][3]
set_location_assignment PIN_MK49 -to mem_dqs_n[0][2]
set_location_assignment PIN_MA40 -to mem_dqs_n[0][1]
set_location_assignment PIN_MK37 -to mem_dqs_n[0][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V POD" -to mem_dqs_n[0][*]
set_location_assignment PIN_LR57 -to mem_dbi_n[0][8]
set_location_assignment PIN_MD54 -to mem_dbi_n[0][7]
set_location_assignment PIN_MD60 -to mem_dbi_n[0][6]
set_location_assignment PIN_LB52 -to mem_dbi_n[0][5]
set_location_assignment PIN_LR51 -to mem_dbi_n[0][4]
set_location_assignment PIN_MD42 -to mem_dbi_n[0][3]
set_location_assignment PIN_MD48 -to mem_dbi_n[0][2]
set_location_assignment PIN_LR39 -to mem_dbi_n[0][1]
set_location_assignment PIN_MD36 -to mem_dbi_n[0][0]
set_instance_assignment -name IO_STANDARD "1.2-V POD" -to mem_dbi_n[0][*]
#-------DDR4 COMP CH1 PIN ASSIGNMENT--------#
set_location_assignment PIN_KU36 -to mem_refclk[1]
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to mem_refclk[1] -entity ddr4
set_location_assignment PIN_KR39 -to mem_ck[1][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V SSTL" -to mem_ck[1][0]
set_location_assignment PIN_KU38 -to mem_ck_n[1][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V SSTL" -to mem_ck_n[1][0]
set_location_assignment PIN_KR43 -to mem_bg[1][1]
set_location_assignment PIN_KF32 -to mem_bg[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_bg[1][*]
set_location_assignment PIN_KJ33 -to mem_ba[1][1]
set_location_assignment PIN_KR33 -to mem_ba[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_ba[1][*]
set_location_assignment PIN_KU32 -to mem_alert_n[1]
set_location_assignment PIN_KJ37 -to mem_oct_rzqin[1]
set_location_assignment PIN_KJ39 -to mem_par[1]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_par[1]
set_location_assignment PIN_KF40 -to mem_cke[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_cke[1][0]
set_location_assignment PIN_KU40 -to mem_odt[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_odt[1][0]
set_location_assignment PIN_KJ43 -to mem_act_n[1]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_act_n[1]
set_location_assignment PIN_KF42 -to mem_cs_n[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_cs_n[1][0]
set_location_assignment PIN_KU42 -to mem_reset_n[1]
set_location_assignment PIN_KJ35 -to mem_a[1][16]
set_location_assignment PIN_KF34 -to mem_a[1][15]
set_location_assignment PIN_KR35 -to mem_a[1][14]
set_location_assignment PIN_KU34 -to mem_a[1][13]
set_location_assignment PIN_KF36 -to mem_a[1][12]
set_location_assignment PIN_LB38 -to mem_a[1][11]
set_location_assignment PIN_KW39 -to mem_a[1][10]
set_location_assignment PIN_LL39 -to mem_a[1][9]
set_location_assignment PIN_LH38 -to mem_a[1][8]
set_location_assignment PIN_KW41 -to mem_a[1][7]
set_location_assignment PIN_LB40 -to mem_a[1][6]
set_location_assignment PIN_LL41 -to mem_a[1][5]
set_location_assignment PIN_LH40 -to mem_a[1][4]
set_location_assignment PIN_LB42 -to mem_a[1][3]
set_location_assignment PIN_KW43 -to mem_a[1][2]
set_location_assignment PIN_LL43 -to mem_a[1][1]
set_location_assignment PIN_LH42 -to mem_a[1][0]
set_instance_assignment -name IO_STANDARD "SSTL-12" -to mem_a[1][*]
set_location_assignment PIN_LU4 -to mem_dq[1][71]
set_location_assignment PIN_LN11 -to mem_dq[1][70]
set_location_assignment PIN_MC5 -to mem_dq[1][69]
set_location_assignment PIN_MA11 -to mem_dq[1][68]
set_location_assignment PIN_LW2 -to mem_dq[1][67]
set_location_assignment PIN_LW9 -to mem_dq[1][66]
set_location_assignment PIN_MA4 -to mem_dq[1][65]
set_location_assignment PIN_LR9 -to mem_dq[1][64]
set_location_assignment PIN_LN23 -to mem_dq[1][63]
set_location_assignment PIN_MA15 -to mem_dq[1][62]
set_location_assignment PIN_MA23 -to mem_dq[1][61]
set_location_assignment PIN_LN15 -to mem_dq[1][60]
set_location_assignment PIN_LR21 -to mem_dq[1][59]
set_location_assignment PIN_LW13 -to mem_dq[1][58]
set_location_assignment PIN_LW21 -to mem_dq[1][57]
set_location_assignment PIN_LR13 -to mem_dq[1][56]
set_location_assignment PIN_MC17 -to mem_dq[1][55]
set_location_assignment PIN_MF5 -to mem_dq[1][54]
set_location_assignment PIN_MK17 -to mem_dq[1][53]
set_location_assignment PIN_MD7 -to mem_dq[1][52]
set_location_assignment PIN_MD15 -to mem_dq[1][51]
set_location_assignment PIN_MC9 -to mem_dq[1][50]
set_location_assignment PIN_MH15 -to mem_dq[1][49]
set_location_assignment PIN_MH7 -to mem_dq[1][48]
set_location_assignment PIN_MA30 -to mem_dq[1][47]
set_location_assignment PIN_MA26 -to mem_dq[1][46]
set_location_assignment PIN_LN30 -to mem_dq[1][45]
set_location_assignment PIN_LR25 -to mem_dq[1][44]
set_location_assignment PIN_LR29 -to mem_dq[1][43]
set_location_assignment PIN_LW25 -to mem_dq[1][42]
set_location_assignment PIN_LW29 -to mem_dq[1][41]
set_location_assignment PIN_LN26 -to mem_dq[1][40]
set_location_assignment PIN_JL37 -to mem_dq[1][39]
set_location_assignment PIN_JL33 -to mem_dq[1][38]
set_location_assignment PIN_JP36 -to mem_dq[1][37]
set_location_assignment PIN_JP32 -to mem_dq[1][36]
set_location_assignment PIN_KC37 -to mem_dq[1][35]
set_location_assignment PIN_KC33 -to mem_dq[1][34]
set_location_assignment PIN_JY36 -to mem_dq[1][33]
set_location_assignment PIN_JY32 -to mem_dq[1][32]
set_location_assignment PIN_LB36 -to mem_dq[1][31]
set_location_assignment PIN_KW37 -to mem_dq[1][30]
set_location_assignment PIN_LL37 -to mem_dq[1][29]
set_location_assignment PIN_LB32 -to mem_dq[1][28]
set_location_assignment PIN_LH36 -to mem_dq[1][27]
set_location_assignment PIN_LL33 -to mem_dq[1][26]
set_location_assignment PIN_KW33 -to mem_dq[1][25]
set_location_assignment PIN_LH32 -to mem_dq[1][24]
set_location_assignment PIN_MC27 -to mem_dq[1][23]
set_location_assignment PIN_MC21 -to mem_dq[1][22]
set_location_assignment PIN_MK27 -to mem_dq[1][21]
set_location_assignment PIN_MD19 -to mem_dq[1][20]
set_location_assignment PIN_MD26 -to mem_dq[1][19]
set_location_assignment PIN_MK21 -to mem_dq[1][18]
set_location_assignment PIN_MH26 -to mem_dq[1][17]
set_location_assignment PIN_MH19 -to mem_dq[1][16]
set_location_assignment PIN_MA36 -to mem_dq[1][15]
set_location_assignment PIN_MA32 -to mem_dq[1][14]
set_location_assignment PIN_LN36 -to mem_dq[1][13]
set_location_assignment PIN_LR31 -to mem_dq[1][12]
set_location_assignment PIN_LR35 -to mem_dq[1][11]
set_location_assignment PIN_LW31 -to mem_dq[1][10]
set_location_assignment PIN_LW35 -to mem_dq[1][9]
set_location_assignment PIN_LN32 -to mem_dq[1][8]
set_location_assignment PIN_MC33 -to mem_dq[1][7]
set_location_assignment PIN_MD28 -to mem_dq[1][6]
set_location_assignment PIN_MK33 -to mem_dq[1][5]
set_location_assignment PIN_MH28 -to mem_dq[1][4]
set_location_assignment PIN_MD32 -to mem_dq[1][3]
set_location_assignment PIN_MK29 -to mem_dq[1][2]
set_location_assignment PIN_MH32 -to mem_dq[1][1]
set_location_assignment PIN_MC29 -to mem_dq[1][0]
set_location_assignment PIN_LW5 -to mem_dqs[1][8]
set_location_assignment PIN_LW17 -to mem_dqs[1][7]
set_location_assignment PIN_MH11 -to mem_dqs[1][6]
set_location_assignment PIN_LW27 -to mem_dqs[1][5]
set_location_assignment PIN_JY34 -to mem_dqs[1][4]
set_location_assignment PIN_LH34 -to mem_dqs[1][3]
set_location_assignment PIN_MH23 -to mem_dqs[1][2]
set_location_assignment PIN_LW33 -to mem_dqs[1][1]
set_location_assignment PIN_MH30 -to mem_dqs[1][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V POD" -to mem_dqs[1][*]
set_location_assignment PIN_MA7 -to mem_dqs_n[1][8]
set_location_assignment PIN_MA19 -to mem_dqs_n[1][7]
set_location_assignment PIN_MK13 -to mem_dqs_n[1][6]
set_location_assignment PIN_MA28 -to mem_dqs_n[1][5]
set_location_assignment PIN_KC35 -to mem_dqs_n[1][4]
set_location_assignment PIN_LL35 -to mem_dqs_n[1][3]
set_location_assignment PIN_MK25 -to mem_dqs_n[1][2]
set_location_assignment PIN_MA34 -to mem_dqs_n[1][1]
set_location_assignment PIN_MK31 -to mem_dqs_n[1][0]
set_instance_assignment -name IO_STANDARD "DIFFERENTIAL 1.2-V POD" -to mem_dqs_n[1][*]
set_location_assignment PIN_LR5 -to mem_dbi_n[1][8]
set_location_assignment PIN_LR17 -to mem_dbi_n[1][7]
set_location_assignment PIN_MD11 -to mem_dbi_n[1][6]
set_location_assignment PIN_LR27 -to mem_dbi_n[1][5]
set_location_assignment PIN_JP34 -to mem_dbi_n[1][4]
set_location_assignment PIN_LB34 -to mem_dbi_n[1][3]
set_location_assignment PIN_MD23 -to mem_dbi_n[1][2]
set_location_assignment PIN_LR33 -to mem_dbi_n[1][1]
set_location_assignment PIN_MD30 -to mem_dbi_n[1][0]
set_instance_assignment -name IO_STANDARD "1.2-V POD" -to mem_dbi_n[1][*]
- RongY_altera
Contributor
I've tried few older versions, even Quartus 22.4 Pro generates example design for AGIB027R29A1E2VR3, not for AGIB027R29A1E2VR0.
Using an old example design is not recommended since it may contain some known issues. I suggest you to generate an example design for DK-DEV-AGI027R1BES. It's also power solution 1. Then modify OPN and necessary settings for DK-DEV-AGI027RES.
Rong
