Agilex 7 R-Tile RES FPGA – CXL Device Enumeration Failure with CXL IP Design Example
What's the Quartus version you're using?
Please use Q23.4 Pro onwards.
Rong
Hi Rong,
We have tried Quartus Pro 24.3 and 24.1, both newer than 23.4. The CXL design example fails to bring up the device on both Quartus versions.
- RongY_altera9 months ago
Contributor
You may need to put two DDR4-2666 DIMM memory onto the dev kit.
Rong
- nskim8 months ago
Hi Rong,
We programmed the same bitstream onto another FPGA in our lab, and it works correctly on that device. Based on our understanding, the Agilex 7 I-series card already has 16 GB of on-card DRAM, and the CXL design example is expected to work with this configuration. In addition, we also tested a PCIe IP configuration that does not require external memory, but it failed as well.
Please let us know if installing the two DDR4-2666 DIMMs is still required in this case.
