nskim's avatar
nskim
9 months ago
Agilex 7 R-Tile RES FPGA – CXL Device Enumeration Failure with CXL IP Design Example
OPN:DK-DEV-AGI027RES (Power Solution 1) SN: AGIPCIE8000296 1.Failure Symptom The CXL device fails to enumerate when using the CXL Type-3 IP design example. •    lspci -vvv | grep 0ddb does not ...
