nskim
9 months agoAgilex 7 R-Tile RES FPGA – CXL Device Enumeration Failure with CXL IP Design Example
OPN:DK-DEV-AGI027RES (Power Solution 1) SN: AGIPCIE8000296 1.Failure Symptom The CXL device fails to enumerate when using the CXL Type-3 IP design example. • lspci -vvv | grep 0ddb does not ...
nskim
9 months agoHi Rong,
We have tried Quartus Pro 24.3 and 24.1, both newer than 23.4. The CXL design example fails to bring up the device on both Quartus versions.
RongY_altera
Contributor
9 months agoYou may need to put two DDR4-2666 DIMM memory onto the dev kit.
Rong
- nskim8 months ago
Hi Rong,
We programmed the same bitstream onto another FPGA in our lab, and it works correctly on that device. Based on our understanding, the Agilex 7 I-series card already has 16 GB of on-card DRAM, and the CXL design example is expected to work with this configuration. In addition, we also tested a PCIe IP configuration that does not require external memory, but it failed as well.
Please let us know if installing the two DDR4-2666 DIMMs is still required in this case.
