AGILEX 7-I R-Tile PCIe Root port : Unsupported Request received after enumeration
Hi Serge,
Not sure I understand those signals. You're using Gen2 x2 and rx_st0_hdr_int data is not correct, is that your question?
Rong
- Serge931 year ago
Hello Rong,
Which signals do you not understand ?
The PCIe configuration is Gen3x4.
The following signals :
slow_clk
slow_clk_resetn
avs_reconfig_address(31:0)
avs_reconfig_read
avs_reconfig_readdata(7:0)
avs_reconfig_readdatavalid
avs_reconfig_write
avs_reconfig_writedata(7:0)
avs_reconfig_waitrequest
enable to configure registers in the PCIe IP configured as a Root por, mainly for PCIe Enumeration.
Tx_st0_sop
Tx_st0_eop
Tx_st0_hvalid
Tx_st0_hdr(127:0)
Tx_st0_dvalid
Tx_st0_data(127:0)
Tx_st1_sop
Tx_st1_eop
Tx_st1_hvalid
Tx_st1_hdr(127:0)
Tx_st1_dvalid
Tx_st1_data(127:0)
Tx_ready
Enable to send PCIe commands to the PCIe Target (SSD) ( config Write, config Read, Memory write, Memeory read, etc..)
Rx_st0_sop
Rx_st0_eop
Rx_st0_hvalid
Rx_st0_hdr(127:0)
Rx_st0_dvalid
Rx_st0_data(127:0)
Rx_st0_empty(1:0)
Rx_st1_sop
Rx_st1_eop
Rx_st1_hvalid
Rx_st1_hdr(127:0)
Rx_st1_dvalid
Rx_st1_data(127:0)
Rx_st1_empty(1:0)
Enables to receive PCIe commands from the PCIe Target (SSD) ( Completion with or without data, Memory write, Memeory read, etc..)
My question is :
What is wrong in my command sequence to get an unsupported request on the first read after my PCIe enumeration ?
Or, do I miss something to do ?
To answer to this question, you need to analyze my signal tap, on which you have all the accesses recorded included the Unsupoorted Request Completion.
On my side I do not see what is wrong.
Thanks for help.
Serge
