Serge93
1 year agoAGILEX 7-I R-Tile PCIe Root port : Unsupported Request received after enumeration
hello, I am using the the Agilex 7-I r-tile Dev kit board in PCIe Root Port. After I have done my enumaration when I am doing a Memory Read of one 32-Bits data, I receive a completion with 'Unsuppo...
RongY_altera
Contributor
1 year ago2) Can you detail what you mean by the PCIe Command Register ? What address ? in Root Port or in Target ?
-->PCIe configuration space offset 0x4. Check RP side. Bit 1 is for Memory Space Enable.
Rong
Serge93
1 year agoHello Rong,
Yes Bit 1 and Bit 2 are set to 1.
Have you read the Signal Tap I sent you ?
Serge
