Agilex 7 HBM2E burst length
- 3 months ago
Hi FBuss2 ,
HBM2E operates with fixed internal burst lengths (BL4/BL8).
In BL8 mode, each internal column access returns a full BL8 worth of data.
A 1‑beat AXI write on a narrow port often forces read‑modify‑write internally; a 1‑beat read fetches a full internal BL8 but delivers only one byte on AXI.
This is highly inefficient and can degrade throughput and increase power.
Adzim
And a related question: what is the max burst length? The port is 8 bits wide, but it doesn't work if I use a length greater than 64 in BL8 mode.
- AdzimZM_Altera3 months ago
Hi FBuss2,
Sorry for the delay to reply. I was OOO last week and not able to reply on time.
Can you provide the HBM2E IP setting that you configured?
Are you testing on a Agilex 7 M devkit or a custom board?
Did you used example design to run the test or used your own design?
Adzim
- FBuss23 months ago
Here are all the IP configurations of the project: https://frank-buss.de/tmp/ip.zip
Mostly default settings for the HBM2E IP, just BL8 enabled. I'm using the IA-860m PCIe card, with my own design, based on the card vendor cardtest example. Quartus version is 25.3.1, with patch 1.02 installed.- AdzimZM_Altera3 months ago
Hi FBuss2,
When running the test, what is the AXSIZE and AXLEN you used?
Could be possible the test has cross 4KB boundary.
Adzim
