Agilex 7 Decoupling capacitor scaling factor
Hi Farabi,
Thanks for your reply. I have doubt , the power consumption generated from Quartus , is power consumption of my logic, right? Then how i can take that value as a maximum power consumption of each supply rail.
In datasheet it mentioned , scaling factor is the ratio of board's power consumption to maximum power per rail. So , I got my board's power consumption value through Quartus software. Now I need the value for maximum power per rail. Where should I find the value?
Vigneswaran
- Farabi_Altera4 months ago
Hello Vigneswaran,
Let me explain more details:
1- Power consumption is varies for each design.
2- When you compile your full design with Quartus, Quartus will generate power estimation for each power rails.
3- The report is in <design>.pwr.rpt
4- You will use this report as reference to design your power circuitry.
Please explain if this is NOT what you want.
regards,
Farabi
