SDavi9
7 months agoAgilex 5 PWRMGT IO pin connections
If I am not using the PMBus Power Management function can I leave the following pins unconnected :- PWRMGT_SCL, PWRMGT_SDA, PWRMGT_ALERT Also what about the CvP_CONFDONE pin if we are only ever go...
JohnT_Altera
7 months agoHi,
May I know which device part are you using? If you are using smartVID part then this need to be connected.
