ddeoliveira
3 months agoAgilex 5 configuration via Avalon-ST x8 issues
I have a MAX10 device controlling the configuration of an Agilex 5 device (A5EC065BB23AI4S) set for Avalon-ST x8. We use the MAX10 to translate serial programming from our processor to AvalonST x8 ...
Farabi_Altera
2 months agoHello,
Please make sure below connection are implemented:
1- nCONFIG pull up to VCCIO_SDM via 10kOhm resistor
2- nSTATUS pullup to VCCIO_SDM via 10kOhm resistor
3- CONF_DONE is based on your selection of SDM IO pin, default SDM_IO16. If you select other than SDM_IO0 or SDMIO16, you need to connect external 4.7kOhm pulldown resistor to this pin.
regards,
Farabi
