Agilex 5 - configure FPGA from running linux via dt-overlay
I am using HPS-first configuration scheme and I can fit FPGA from u-boot(first time it is successfull). Now I want to refit FPGA from running linux system. I am trying to follow this manual
https://device.report/m/dfbc733be8e55f3eeb1bd826b10d227bc67cef0500f56fd4ceedb63459e4e408.pdf
section 6.2. Configuring the FPGA Fabric from Linux, but I am getting error:
# echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path sh: write error: Invalid argument
this is my overlay dts file
/dts-v1/; /plugin/; / { fragment@0 { target-path = "/soc/base_fpga_region"; #address-cells = <1>; #size-cells = <1>; __overlay__ { #address-cells = <1>; #size-cells = <1>; /* ranges = <0x00000000 0xF9000000 0x00200000>;*/ firmware-name = "fpga_core.rbf"; config-complete-timeout-us = <10000000>; /* sysid@0 { compatible = "altr,sysid-20.1", "altr,sysid-1.0"; reg = <0x00000000 0x00000008>; id = <0x12345678>; timestamp = <0>; };*/ }; }; };
I have tried dts also with commented lines, also without success.
dmesg relevant lines:
STARTUP: ... [ 0.036001] FPGA manager framework ... [ 1.591366] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.598563] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 1.606865] Stratix10 SoC FPGA manager soc@0:firmware:svc:fpga-mgr: couldn't get service channel (fpga) ... [ 1.706286] stratix10-svc soc@0:firmware:svc: Adding to iommu group 3 [ 1.717674] Intel Service Layer Driver Initialized ... [ 1.768068] fpga_manager fpga0: Stratix10 SOC FPGA Manager registered [ 1.795620] of-fpga-region soc@0:base_fpga_region: FPGA Region probed ... Dduring DT overlay apply: [ 575.816996] OF: overlay: find target, node: /fragment@0, path '/soc/base_fpga_region' not found [ 575.825722] OF: overlay: init_overlay_changeset() failed, ret = -22 [ 575.831968] create_overlay: Failed to create overlay (err=-22)
in ...intel/socfpga_agilex5.dtsi there is section:
... soc: soc@0 { compatible = "simple-bus"; ranges = <0 0 0 0xffffffff>; #address-cells = <1>; #size-cells = <1>; device_type = "soc"; interrupt-parent = <&intc>; base_fpga_region { #address-cells = <0x2>; #size-cells = <0x2>; compatible = "fpga-region"; fpga-mgr = <&fpga_mgr>; }; ...
according this page
https://www.rocketboards.org/foswiki/Documentation/IntelFPGAHPSEmbeddedSoftwareRelease
there was problem
FPGA configuration with overlays fails after seeing the following message during Linux boot up: "Stratix10 SoC FPGA manager soc:firmware:svc:fpga-mgr: couldn't get service channel (fpga)"
, but it should be fixed in 24.2 PRO version (I am using 24.3.1 PRO version)
Could you help me wth this problem, please? Is problem the target_path variable?
Hi all,
finally I solved issues with help from Arrow (thank you Tomasz). The necessary things were:
1) to modify u-boot script to exclude any accesses to fabric peripherals (eg USB reset PIO)
echo "Trying to boot Linux from device ${target}"; if test ${target} = "mmc0"; then mw.l 10d13224 14; mw.l 10d13228 14; mw.l 10d1323c 14; mw.l 10d13234 14; mw.l 10d13248 14; mw.l 10d1324C 14; mw.l 0x10D11028 0x01027fb0 1; mw.l 0x10c03304 0x410 1; mw.l 0x10c03300 0x00000410; mw.l 0x10c03300 0x00000000; mw.l 0x10c03300 0x00000410; else echo "mmc0 not found!" fi fatload mmc 0:1 ${loadaddr} ${bootfile}; setenv bootargs "bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait"; bootm ${loadaddr}; if test ${target} = "qspi"; then qspi_clock=0x17d78400; if ubi part root; then ubi detach; mtdparts; ubi part root; ubi readvol ${loadaddr} kernel; ubi detach; setenv bootargs "earlycon panic=-1 ubi.mtd=1 root=ubi0:rootfs rootfstype=ubifs rw rootwait"; bootm ${loadaddr}; fi ubi detach; sf probe; sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize}; setenv bootargs "earlycon root=/dev/mtdblock1 rw rootfstype=jffs2 rootwait"; bootm ${loadaddr}; fi if test ${target} = "nand"; then ubi part root; ubi readvol ${loadaddr} kernel; setenv bootargs "earlycon panic=-1 root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1"; bootm ${loadaddr}; fi2.) To modify and rebuild the devicetree (socfpga_agilex5_axe5_eagle.dts). Remove any references to fabric peripherals - so LEDs sections, whole soc@0 section and &usb31 section.
overlay.dts was also simplified
// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2024, Arrow Electronics, Incorporated. */ /dts-v1/; /plugin/; / { fragment@0 { target-path = "/soc@0/base_fpga_region"; __overlay__ { firmware-name = "axe5_eagle_top.hps.core.rbf"; config-complete-timeout-us = <30000000>; }; }; };and now fpga_core.rbf can be (for first time) succesfully load also from linux system.
- MM-ATH
It seems, that target_path variable should be
but after "echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path" system hangs. This is output on serial line:
echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path [ 39.285147] fpga_manager fpga0: writing fpga_core.rbf to Stratix10 SOC FPGA Manager PANIC at PC : 0x000000008000b420Maybe it is necessary to manually disable bridges or something else that is beyond my knowledge...
Any advice is welcome.
- MM-ATH
Hi all,
