Agilex 5 - configure FPGA from running linux via dt-overlay
- 1 year ago
Hi all,
finally I solved issues with help from Arrow (thank you Tomasz). The necessary things were:
1) to modify u-boot script to exclude any accesses to fabric peripherals (eg USB reset PIO)
echo "Trying to boot Linux from device ${target}"; if test ${target} = "mmc0"; then mw.l 10d13224 14; mw.l 10d13228 14; mw.l 10d1323c 14; mw.l 10d13234 14; mw.l 10d13248 14; mw.l 10d1324C 14; mw.l 0x10D11028 0x01027fb0 1; mw.l 0x10c03304 0x410 1; mw.l 0x10c03300 0x00000410; mw.l 0x10c03300 0x00000000; mw.l 0x10c03300 0x00000410; else echo "mmc0 not found!" fi fatload mmc 0:1 ${loadaddr} ${bootfile}; setenv bootargs "bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait"; bootm ${loadaddr}; if test ${target} = "qspi"; then qspi_clock=0x17d78400; if ubi part root; then ubi detach; mtdparts; ubi part root; ubi readvol ${loadaddr} kernel; ubi detach; setenv bootargs "earlycon panic=-1 ubi.mtd=1 root=ubi0:rootfs rootfstype=ubifs rw rootwait"; bootm ${loadaddr}; fi ubi detach; sf probe; sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize}; setenv bootargs "earlycon root=/dev/mtdblock1 rw rootfstype=jffs2 rootwait"; bootm ${loadaddr}; fi if test ${target} = "nand"; then ubi part root; ubi readvol ${loadaddr} kernel; setenv bootargs "earlycon panic=-1 root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1"; bootm ${loadaddr}; fi2.) To modify and rebuild the devicetree (socfpga_agilex5_axe5_eagle.dts). Remove any references to fabric peripherals - so LEDs sections, whole soc@0 section and &usb31 section.
overlay.dts was also simplified
// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2024, Arrow Electronics, Incorporated. */ /dts-v1/; /plugin/; / { fragment@0 { target-path = "/soc@0/base_fpga_region"; __overlay__ { firmware-name = "axe5_eagle_top.hps.core.rbf"; config-complete-timeout-us = <30000000>; }; }; };and now fpga_core.rbf can be (for first time) succesfully load also from linux system.
It seems, that target_path variable should be
but after "echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path" system hangs. This is output on serial line:
echo fpga_core.dtb > /sys/kernel/config/device-tree/overlays/0/path [ 39.285147] fpga_manager fpga0: writing fpga_core.rbf to Stratix10 SOC FPGA Manager PANIC at PC : 0x000000008000b420
Maybe it is necessary to manually disable bridges or something else that is beyond my knowledge...
Any advice is welcome.
- MM-ATH1 year ago
Hi all,
