Agilex 3 VCCLSENSE and GNDSENSE
First thing is that whether the regulator that you choose is from a recommended list or not. Refer to
Secondly, the VCCLSENSE and GNDSENSE are recommended to be a must connected pins for VCC core. These pins compensates for the DC IR drop associated with the PCB and device package from the VCC power.
Altera strongly recommends to follow the guidelines provided for a smooth operation of the device. Any design outside the recommendations will not be supported. It will be at user risk.
Altera support
Yes, the Agilex 3 does NOT require a SmartVID compatible regulator. You can provide a fixed voltage to VCC as mentioned in the datasheet.
However on the VCCLSENSE and GNDSENSE pins, these pins compensates for the DC IR drop associated with the PCB and device package from the VCC power. It is recommended to connect them to the regulator.
