Agilex 3 VCCLSENSE and GNDSENSE
First thing is that whether the regulator that you choose is from a recommended list or not. Refer to
Secondly, the VCCLSENSE and GNDSENSE are recommended to be a must connected pins for VCC core. These pins compensates for the DC IR drop associated with the PCB and device package from the VCC power.
Altera strongly recommends to follow the guidelines provided for a smooth operation of the device. Any design outside the recommendations will not be supported. It will be at user risk.
Altera support
- Ash_R_Altera2 months ago
I recommend that you choose the regulator that suites your current requirement from the vendor list that we have validated with, as it is crucial for the regulators to be SmartVID compatible with the FPGA devices.
For the SENSE, pin it is a strong recommendation to connect to the regulator pins and do not leave them unconnected.
- Robert_PIN_ASAP2 months ago
Thank you for the reply and information, but the Agilex 3 datasheet states that Vcc is a fixed voltage.
It's nice to have recommendations, but if we choose a regulator that meets the requirements stated in the datasheet, then that should be sufficient.
The Agilex 3 Pin Connection Guideline states that the sense pins are outputs. If these are truly outputs, then I would think it's OK to leave them floating if our regulator doesn't support remote sense.
In the case of our very small PCB with a power plane, I believe we can ensure that we will meet the VCC requirements without using a more expensive regulator that supports remote voltage sense.
Yes, the Agilex 3 does NOT require a SmartVID compatible regulator. You can provide a fixed voltage to VCC as mentioned in the datasheet.
However on the VCCLSENSE and GNDSENSE pins, these pins compensates for the DC IR drop associated with the PCB and device package from the VCC power. It is recommended to connect them to the regulator.
