BXia's avatar
BXia
2 days ago
AGIB027R29A1E2VC suppoprts LPO?
  • Farabi_Altera's avatar
    Farabi_Altera
    Looking at the available documentation for the AGIB027R29A1E2VC (Agilex 7 I-Series), I don't have specific LPO (Linear Pre-drive Output / Local Oscillator, or Linear-drive Pluggable Optics — whichever you mean) support details in the sources available to me.
    What I can confirm about this device's transceiver configuration:
    It carries 64 F-Tile FGT transceiver channels, 8 F-Tile FHT transceiver channels, and an R-Tile PCIe/CXL controller, with 32 CXL lanes. https://docs.altera.com/r/docs/683458/current/agilextm-7-fpgas-and-socs-device-overview/agilextm-7-fpgas-and-socs-f-series
    The transceivers support data rates up to 58 Gbps. Agilex™ 7 FPGAs and SoCs Device Overview
    The Agilex 7 I-Series uses F-Tile and R-Tile transceiver types (E-Tile and P-Tile are not present in this series). Agilex™ 7 FPGAs and SoCs Device Overview
    However, LPO (Linear Pluggable Optics) support — which involves specific transceiver analog output drive characteristics and DSP bypass modes — is not explicitly documented in the sources I have available for this part. This is a nuanced transceiver feature that depends on F-Tile analog drive capability details.
    I'd recommend checking the Agilex 7 F-Tile Transceiver PHY User Guide and the Agilex 7 F-Series and I-Series Known Issue List directly on the Altera documentation portal for the most current LPO support status, as this is the kind of feature that may also be subject to silicon revision constraints. Note also that Agilex 7 production devices manufactured before 2024 had FHT transceiver EOJ performance limitations, with devices manufactured in 2024 and beyond being fully compliant with published specifications Agilex™ 7 F-Series and I-Series Known Issue List — so silicon date code can matter for high-speed transceiver features.
