- JohnT_Altera
May I know what do you mean PHY communication is not working? The dual configuration and watchdog timer shouldn't impact your PHY communication. Could you check if your design is working correctly?
- KWang97
Ir shouldn't influnce the PHY comminication and I also wonder why. But PHY comminication works well when I disable the watchdog. While after I enable watchdog, the PHY communication works unnormally. Every dozens of seconds the communication will be missing for around 2 seconds. It seems like the PHY is reset. But I don't know why?
And is what I modified in the code for reseting watchdog right? Thanks!
- JohnT_Altera
May I know how do you confirm if the correct image is loaded into the FPGA? Does both image will have the PHY communication work? Is there any different between the 2 image?
- KWang97
I programmed the same pof file into both image0 and iamge1.
- JohnT_Altera
May I know if you observed PHY communication down, do you observed the image reconfigure? Are you able to check if you assert the reset the watchdog timer correctly?
- KWang97
Yes, I see PHY communication down with Link LED on while it should be always off in normal situation.
The image didn't reconfigure because I didn't trigger it at all. And other parts of my code runs normally.
As to the Are you able to check if you assert the reset the watchdog timer correctly, that's what I am discussing with you and I also upload the code above 30minutes ago. So please help me see if it's OK?
- JohnT_Altera
The code looks goods. I just ask to double confirm in hardware but since you mention that reconfiguration is not happening is not happening then it should be fine. You will need to further debug what is actually happening that cause teh PHY communication to be down.
- KWang97
It happens once I enable the watchdog , even I didn't use dual-config IP(write any code to dual-config IP). so I wonder why this can influnce PHY communication.@JohnT_Intel
- JohnT_Altera
Could you increase the watchdog timer to 0x1FFF?
- KWang97
I wonder why is 0x1FFF? The value should be 12 bits while 0x1FFF has 13 ones.
