KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
KWang97
6 years agoYes, I see PHY communication down with Link LED on while it should be always off in normal situation.
The image didn't reconfigure because I didn't trigger it at all. And other parts of my code runs normally.
As to the Are you able to check if you assert the reset the watchdog timer correctly, that's what I am discussing with you and I also upload the code above 30minutes ago. So please help me see if it's OK?
