KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
JohnT_Altera
6 years agoHi,
The code looks goods. I just ask to double confirm in hardware but since you mention that reconfiguration is not happening is not happening then it should be fine. You will need to further debug what is actually happening that cause teh PHY communication to be down.
