KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
JohnT_Altera
6 years agoHi,
May I know if you observed PHY communication down, do you observed the image reconfigure? Are you able to check if you assert the reset the watchdog timer correctly?
