Adaptor for USB Blaster II to USB Blaster header
Not sure what you mean by "slightly larger"?
Was your original board built with a 2mm spacing 2x5 header instead of a 2.54mm (100mil) spacing header (I have seen this)?
Both the original USB Blaster and the newer USB BlasterII use a standard 100mil spacing 2x5 header.
If it is shrouded, it must have the polarity notch in the correct orientation.
Unshrouded also works, just need to insure pin1 orientation of connectors align.
I have the data sheets all the way back to the ByteBlasterMV from 1999 and the ISP connector is always
listed as being a 2x5 100mil standard female connector that is 250mil wide by 700mil long.
Same dimensions for all the ByteBlasterXX and USBBlasterXX variations.
You may need to send a photo of what does not fit.
- mark_blackburn3 years ago
Here's a photo of the USB Blaster vs USB Blaster II connectors:
Here's a photo of the USB Blaster mated to our board. The shrouded connector just fits the USB Blaster connector. There's no room for the wider USB Blaster II connector:
- FvM3 years ago
Agree with the above. All Intel and third Party dev boards as well as our own design have a JTAG connector fitting both USB Blaster versions. It's true that the USB Blaster version with FPC cable uses a connector without polarity notch, never noticed it would be smaller than standard 0.1" connector.
Anyway, there are male IPC connectors on the market, you can make your own adapter.
