14 years ago
about external pll in lvds_rx and lvds_tx
i am new to lvds mega in quartus . i wanna know that what is the difference between using internal pll and external pll,since there is an option in the lvds_tx, lvds_rx general pannel. which kind configuration is easier and more stable? and my device is ep2c35.
thanks !
yu.p
    --- Quote Start ---
    You should really read the altlvds MegaCore users guide:
    http://www.altera.com/literature/ug/ug_altlvds.pdf
    and simulate the component in Modelsim. Getting it to work there will show you what the clocks need to be.
    Cheers,
    Dave
    --- Quote End ---
    Thanks Dave!
    i have almost tried every option to apply altlvds, i recived the data,but the data and the clock had some phase difference. And at last, I gave up the altlvds, and wrote one by myself. Now ,it works well.
    Thanks again!
    yu.p
    --- Quote Start ---
    Is the frame clock you mentioned above the tx_syncclock in altlvds?
    i send it.And the LVDS have terminations.
    --- Quote End ---
    Cheers,
    Dave
    --- Quote Start ---
    If you do it right, it will work well.
    Have you simulated your design in Modelsim?
    Are you sending a frame clock to frame your LVDS data? For example, if you are serializing 8:1, and then deserializing 1:8, you should be sending a frame clock that is 1/8th of the data rate.
    Have you ensured that your LVDS receivers have terminations?
    Cheers.
    Dave
    --- Quote End ---
    --- Quote Start ---
    I send the data and the fast clock of altlvds_tx to the altlvds_rx. The connection is tx_inclk ------> rx_inclk, tx_out----------------> rx_in.The altlvds works, but the data received is not right.
    Any suggestion to solve the problem ? And could my method work well ?
    --- Quote End ---
    Cheers.
    Dave
    --- Quote Start ---
    The altlvds component with PLL or with external PLL uses the same PLL component within the FPGA. If you have not routed a global clock input on your board, then you are in trouble.
    Cheers,
    Dave
    --- Quote End ---
    Thanks ! i know that no matter internal or external plls i used in altlvds, they are the pll in the FPGA. And now, I send the data and the fast clock of altlvds_tx to the altlvds_rx. The connection is tx_inclk ------> rx_inclk, tx_out----------------> rx_in.The altlvds works, but the data received is not right.
    Thanks dave!
    yu.p
    --- Quote Start ---
    Our board have been made that the inclk ports are not drawn out. So i cann't use the internal pll of the lvds mega, and the internal pll of lvds mega needs a inlck to feed the pll.
    I will try the external pll .
    --- Quote End ---
    Cheers,
    Dave
    --- Quote Start ---
    Use the internal PLL unless you need to dynamically controller the PLL parameters. The default configuration takes care of the timing analysis constraints.
    Cheers,
    Dave
    --- Quote End ---
    Thanks dave!Our board have been made that the inclk ports are not drawn out. So i cann't use the internal pll of the lvds mega, and the internal pll of lvds mega needs a inlck to feed the pll.
    Thanks !
    yu.p
    --- Quote Start ---
    thanks !
    yu.p
    --- Quote End ---
    Cheers,
    Dave
