14 years agoabout external pll in lvds_rx and lvds_tx
i am new to lvds mega in quartus . i wanna know that what is the difference between using internal pll and external pll,since there is an option in the lvds_tx, lvds_rx general pannel. which kind co...
14 years ago --- Quote Start --- The altlvds component with PLL or with external PLL uses the same PLL component within the FPGA. If you have not routed a global clock input on your board, then you are in trouble. Cheers, Dave --- Quote End --- Thanks ! i know that no matter internal or external plls i used in altlvds, they are the pll in the FPGA. And now, I send the data and the fast clock of altlvds_tx to the altlvds_rx. The connection is tx_inclk ------> rx_inclk, tx_out----------------> rx_in.The altlvds works, but the data received is not right. Any suggestion to solve the problem ? And could my method work well ? Thanks dave! yu.p
