14 years agoabout external pll in lvds_rx and lvds_tx
i am new to lvds mega in quartus . i wanna know that what is the difference between using internal pll and external pll,since there is an option in the lvds_tx, lvds_rx general pannel. which kind co...
14 years ago --- Quote Start --- I send the data and the fast clock of altlvds_tx to the altlvds_rx. The connection is tx_inclk ------> rx_inclk, tx_out----------------> rx_in.The altlvds works, but the data received is not right. Any suggestion to solve the problem ? And could my method work well ? --- Quote End --- If you do it right, it will work well. Have you simulated your design in Modelsim? Are you sending a frame clock to frame your LVDS data? For example, if you are serializing 8:1, and then deserializing 1:8, you should be sending a frame clock that is 1/8th of the data rate. Have you ensured that your LVDS receivers have terminations? Cheers. Dave
