About ALTIOBUF simulation
thanks Aqid, in fact I'm trying to simulate the IOBUF, which is generated by IP catalog, and compilation cannot pass, attached is the generated file, FYI.
-- megafunction wizard: %ALTIOBUF%
-- GENERATION: STANDARD
-- VERSION: WM1.0
-- MODULE: altiobuf_in
-- File Name: IN_delay_buf.vhd
-- Megafunction Name(s):
-- altiobuf_in
-- Simulation Library Files(s):
-- cyclonev
-- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
-- 17.1.0 Build 590 10/25/2017 SJ Standard Edition
--Copyright (C) 2017 Intel Corporation. All rights reserved.
--Your use of Intel Corporation's design tools, logic functions
--and other software and tools, and its AMPP partner logic
--functions, and any output files from any of the foregoing
--(including device programming or simulation files), and any
--associated documentation or information are expressly subject
--to the terms and conditions of the Intel Program License
--Subscription Agreement, the Intel Quartus Prime License Agreement,
--the Intel FPGA IP License Agreement, or other applicable license
--agreement, including, without limitation, that your use is for
--the sole purpose of programming logic devices manufactured by
--Intel and sold by Intel or its authorized distributors. Please
--refer to the applicable agreement for further details.
--altiobuf_in CBX_AUTO_BLACKBOX="ALL" DEVICE_FAMILY="Cyclone V" ENABLE_BUS_HOLD="FALSE" NUMBER_OF_CHANNELS=1 USE_DIFFERENTIAL_MODE="FALSE" USE_DYNAMIC_TERMINATION_CONTROL="FALSE" USE_IN_DYNAMIC_DELAY_CHAIN="TRUE" datain dataout io_config_clk io_config_clkena io_config_datain io_config_update
--VERSION_BEGIN 17.1 cbx_altiobuf_in 2017:10:25:18:06:52:SJ cbx_mgl 2017:10:25:18:08:29:SJ cbx_stratixiii 2017:10:25:18:06:53:SJ cbx_stratixv 2017:10:25:18:06:53:SJ VERSION_END
LIBRARY cyclonev;
USE cyclonev.all;
--synthesis_resources = cyclonev_delay_chain 1 cyclonev_io_config 1 cyclonev_io_ibuf 1
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY IN_delay_buf_iobuf_in_3jr IS
PORT
datain : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
dataout : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
io_config_clk : IN STD_LOGIC := '0';
io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '0');
io_config_datain : IN STD_LOGIC := '0';
io_config_update : IN STD_LOGIC := '0'
END IN_delay_buf_iobuf_in_3jr;
ARCHITECTURE RTL OF IN_delay_buf_iobuf_in_3jr IS
SIGNAL wire_sd1_dataout : STD_LOGIC;
SIGNAL wire_sd1_delayctrlin : STD_LOGIC_VECTOR (4 DOWNTO 0);
SIGNAL wire_ioconfiga_padtoinputregisterdelaysetting : STD_LOGIC_VECTOR (4 DOWNTO 0);
SIGNAL wire_ibufa_o : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT cyclonev_delay_chain
GENERIC
sim_falling_delay_increment : NATURAL := 10;
sim_intrinsic_falling_delay : NATURAL := 200;
sim_intrinsic_rising_delay : NATURAL := 200;
sim_rising_delay_increment : NATURAL := 10;
lpm_type : STRING := "cyclonev_delay_chain"
PORT
dataout : OUT STD_LOGIC;
delayctrlin : IN STD_LOGIC_VECTOR(4 DOWNTO 0) := (OTHERS => '0')
END COMPONENT;
COMPONENT cyclonev_io_config
GENERIC
enhanced_mode : STRING := "false";
lpm_type : STRING := "cyclonev_io_config"
PORT
dutycycledelaysettings : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
ena : IN STD_LOGIC := '0';
outputenabledelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
outputfinedelaysetting1 : OUT STD_LOGIC;
outputfinedelaysetting2 : OUT STD_LOGIC;
outputhalfratebypass : OUT STD_LOGIC;
outputonlydelaysetting2 : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
outputonlyfinedelaysetting2 : OUT STD_LOGIC;
outputregdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
padtoinputregisterdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
padtoinputregisterfinedelaysetting : OUT STD_LOGIC;
readfifomode : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
readfiforeadclockselect : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
END COMPONENT;
COMPONENT cyclonev_io_ibuf
GENERIC
bus_hold : STRING := "false";
differential_mode : STRING := "false";
simulate_z_as : STRING := "z";
lpm_type : STRING := "cyclonev_io_ibuf"
PORT
dynamicterminationcontrol : IN STD_LOGIC := '0';
i : IN STD_LOGIC := '0';
ibar : IN STD_LOGIC := '0';
o : OUT STD_LOGIC
END COMPONENT;
BEGIN
dataout(0) <= ( wire_sd1_dataout);
wire_sd1_delayctrlin <= ( wire_ioconfiga_padtoinputregisterdelaysetting(4 DOWNTO 0));
sd1 : cyclonev_delay_chain
PORT MAP (
datain => wire_ibufa_o(0),
dataout => wire_sd1_dataout,
delayctrlin => wire_sd1_delayctrlin
ioconfiga : cyclonev_io_config
PORT MAP (
clk => io_config_clk,
datain => io_config_datain,
ena => io_config_clkena(0),
padtoinputregisterdelaysetting => wire_ioconfiga_padtoinputregisterdelaysetting,
update => io_config_update
ibufa : cyclonev_io_ibuf
GENERIC MAP (
bus_hold => "false",
differential_mode => "false"
PORT MAP (
i => datain(0),
o => wire_ibufa_o(0)
END RTL; --IN_delay_buf_iobuf_in_3jr
--VALID FILE
LIBRARY ieee;
ENTITY IN_delay_buf IS
PORT
io_config_clk : IN STD_LOGIC ;
io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
io_config_datain : IN STD_LOGIC ;
io_config_update : IN STD_LOGIC ;
END IN_delay_buf;
ARCHITECTURE RTL OF in_delay_buf IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT IN_delay_buf_iobuf_in_3jr
PORT (
END COMPONENT;
BEGIN
dataout <= sub_wire0(0 DOWNTO 0);
IN_delay_buf_iobuf_in_3jr_component : IN_delay_buf_iobuf_in_3jr
PORT MAP (
datain => datain,
io_config_clk => io_config_clk,
io_config_clkena => io_config_clkena,
io_config_datain => io_config_datain,
io_config_update => io_config_update,
dataout => sub_wire0
END RTL;
-- CNX file retrieval info
-- Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
-- Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
-- Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
-- Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
-- Retrieval info: CONSTANT: enable_bus_hold STRING "FALSE"
-- Retrieval info: CONSTANT: number_of_channels NUMERIC "1"
-- Retrieval info: CONSTANT: use_differential_mode STRING "FALSE"
-- Retrieval info: CONSTANT: use_dynamic_termination_control STRING "FALSE"
-- Retrieval info: CONSTANT: use_in_dynamic_delay_chain STRING "TRUE"
-- Retrieval info: USED_PORT: datain 0 0 1 0 INPUT NODEFVAL "datain[0..0]"
-- Retrieval info: USED_PORT: dataout 0 0 1 0 OUTPUT NODEFVAL "dataout[0..0]"
-- Retrieval info: USED_PORT: io_config_clk 0 0 0 0 INPUT NODEFVAL "io_config_clk"
-- Retrieval info: USED_PORT: io_config_clkena 0 0 1 0 INPUT NODEFVAL "io_config_clkena[0..0]"
-- Retrieval info: USED_PORT: io_config_datain 0 0 0 0 INPUT NODEFVAL "io_config_datain"
-- Retrieval info: USED_PORT: io_config_update 0 0 0 0 INPUT NODEFVAL "io_config_update"
-- Retrieval info: CONNECT: @datain 0 0 1 0 datain 0 0 1 0
-- Retrieval info: CONNECT: @io_config_clk 0 0 0 0 io_config_clk 0 0 0 0
-- Retrieval info: CONNECT: @io_config_clkena 0 0 1 0 io_config_clkena 0 0 1 0
-- Retrieval info: CONNECT: @io_config_datain 0 0 0 0 io_config_datain 0 0 0 0
-- Retrieval info: CONNECT: @io_config_update 0 0 0 0 io_config_update 0 0 0 0
-- Retrieval info: CONNECT: dataout 0 0 1 0 @dataout 0 0 1 0
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.vhd TRUE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.inc FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.cmp TRUE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.bsf FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf_inst.vhd FALSE
-- Retrieval info: LIB_FILE: cyclonev
I have contacted you in private. Can you check your inbox?
