17 years agoa basic timer in VHDL
hi, how can I write a program for a timer which counts up to 6.4 micro seconds?
thanks in advance3 Replies
Tricky gave a solution which is NOT synthesizable. Good for simulation only.
I am agree with Vernmid - Altera_Forum
Use a template from Quartus
Create a new vhdl file. Select edit menu->insert template-> Select VHDL->Full Designs->Counters->Binary Count Then modify then MAX_COUNT value depending on your input clock speed. i.e. how many input clock periods in 6.4us Templates are agood way of finding out how to code various constructs Hope this helps - Altera_Forum
entity timer is end entity timer; architecture time of timer is signal timer : std_logic; begin timer <= '0', '1' after 6.4 us; end architecture time;
