10 years ago10170 Verilog Error
module tcounter (CLK, CLR, ENP, ENT, Q);
input CLK; input CLR; input ENP; input ENT; output [3:0] Q; wire [3:0] inc; treg4bit register( .CLK(CLK), .IN(inc), .RESET(~CLR), .OUT(Q) ); if (ENP & ENT) begin if (Q[2] & Q[1] & Q[0]) begin inc <= 4'b1111; end else if (Q[1] & Q[0]) begin inc <= 4'b0111; end else if (Q[0]) begin inc <= 4'b0011; end else begin inc <= 4'b0001; end end endmodule Errors: Line 15 (10170): near text if, expecting endmodule Line 19 (10170): near text "&", expecting "." or another identifier Line 22 (10170): near text ")", expecting "." or another identifier Any help would be much appreciated http://www.alteraforum.com/forum//images/icons/icon11.png2 Replies
I say this in the nicest possible way - you need to find a good book or tutorial on how to write Verilog code. this (http://www.asic-world.com/verilog/verilog_one_day.html) is a good starting point.
Hi mage76,
there are several issues in your example: As inc is a wire, you need an assign statement for logic. Or define inc as reg, then you could use always @*. 'inc' (as reg) is not initialized, this will infer latches, i am sure you don't want this! Or use inc as reg in combination with 'always @(posedge CLK)', this will infer FFs instead of pure combinatorial logic. If your intention is to create combinatorial logic only you should use '=' instead of '<='.
