Where or how can I get import mgc_axi_pkg::* ?
Hello, I am using Quartus Prime 18.1.0 Standard Edition and ModelSim - Intel Starter Edition 10.5b. I am trying to simulate an HPS design I made on Platform Designer. The macro file fails to load because the above package is missing. The module soc_system_hps_0_fpga_interfaces.sv has the above import statement.
Thanks, Ben Martinez
- AnilErinch_A_Intel
Hi
The package is a part of mentor IP files
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/mentor_vip_ae_usr.pdf
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2016/fatal---vsim-160-------hwsystemtb-simulation-submodules-mgccommo.html
can you check and let us know , whether you are able to find files like mgc_common_axi.sv in your system.
Thanks and Regards
Anil
- BMart12
Hi Anil,
Yes, I found the folder C:\intelFPGA_lite\18.1\ip\altera\mentor_vip_ae\axi3\bfm that has mgc_common_axi.sv and other mgc_axi* files.
Ben
Hi ,
If you check the mgc_common_axi.sv , you should be seeing the package.
package mgc_axi_pkg;
Please check why it is not getting imported , please refer the system verilog guidelines and the scripts which are being used to debug the same.
Thanks and Regards
Anil
- BMart12
Hi Anil, Below is the list of the files in the folder that contains mgc_axi* files. As you see, mgc_axi_pkg is missing. I edited the source file that is importing mgc_axi_pkg.sv to import mgc_axi_bfm_pkg.vhd. I encountered errors due to VHDL differences with Verilog. I am letting go of trying to simulate soc_system. You can close this case unless you can provide me with the missing package. Thanks for your help. Ben Volume in drive C is OS Volume Serial Number is 0AFB-B554 Directory of C:\intelFPGA_lite\18.1\ip\altera\mentor_vip_ae\axi3\bfm 06/16/2020 12:09 PM <DIR> . 06/16/2020 12:09 PM <DIR> .. 06/16/2020 12:09 PM 0 mgc.lst 02/20/2019 04:09 AM 290,692 mgc_axi_bfm_pkg.vhd 02/20/2019 04:09 AM 382 mgc_axi_inline_monitor.mti.svp 02/20/2019 04:09 AM 7,727 mgc_axi_inline_monitor.sv 02/20/2019 04:09 AM 13,034 mgc_axi_inline_monitor.vhd 02/20/2019 04:09 AM 14,996 mgc_axi_inline_monitor_hw.tcl 02/20/2019 04:09 AM 507 mgc_axi_master.mti.svp 02/20/2019 04:09 AM 100,722 mgc_axi_master.sv 02/20/2019 04:09 AM 28,778 mgc_axi_master.vhd 02/20/2019 04:09 AM 10,729 mgc_axi_master_hw.tcl 02/20/2019 04:09 AM 505 mgc_axi_monitor.mti.svp 02/20/2019 04:09 AM 96,028 mgc_axi_monitor.sv 02/20/2019 04:09 AM 34,501 mgc_axi_monitor.vhd 02/20/2019 04:09 AM 505 mgc_axi_slave.mti.svp 02/20/2019 04:09 AM 118,731 mgc_axi_slave.sv 02/20/2019 04:09 AM 34,681 mgc_axi_slave.vhd 02/20/2019 04:09 AM 11,648 mgc_axi_slave_hw.tcl 02/20/2019 04:09 AM 1,674,282 mgc_common_axi.sv 18 File(s) 2,438,448 bytes 2 Dir(s) 366,858,219,520 bytes free
Hi
The package mgc_axi_pkg and its implementation is available inside the file mgc_common_axi.sv.
Thanks and Regards
Anil
- BMart12
Hi Anil, I added the following line to the soc_system.do macro file I am using: vlog -work work +incdir+/home/bmartinez/JT/c5FPGA/JtF31C8_c {/home/bmartinez/JT/c5FPGA/JtF31C8_c/soc_system/testbench/soc_system_tb/simulation/submodules/mgc_common_axi.sv} This inclusion required the following line to resolve “file not found” errors: vlog -work work +incdir+/home/bmartinez/JT/c5FPGA/JtF31C8_c {/home/bmartinez/JT/c5FPGA/JtF31C8_c/soc_system/testbench/soc_system_tb/simulation/submodules/mgc_axi_bfm_pkg.vhd} The next error was for mgc_axi_bfm_pkg, I added the following line: vlog -work work +incdir+/home/bmartinez/JT/c5FPGA/JtF31C8_c {/home/bmartinez/JT/c5FPGA/JtF31C8_c/soc_system/testbench/soc_system_tb/simulation/submodules/mgc_axi_bfm_pkg.vhd} As you can see, the missing package is written in VHDL. I next get the following errors: # ** Error: (vlog-13036) /home/bmartinez/JT/c5FPGA/JtF31C8_c/soc_system/testbench/soc_system_tb/simulation/submodules/mgc_axi_bfm_pkg.vhd(1): near "--": Operator only allowed in SystemVerilog. # ** Error: (vlog-13069) /home/bmartinez/JT/c5FPGA/JtF31C8_c/soc_system/testbench/soc_system_tb/simulation/submodules/mgc_axi_bfm_pkg.vhd(1): near "--": syntax error, unexpected --, expecting class. # End time: 11:32:44 on Jun 17,2020, Elapsed time: 0:00:01 # Errors: 2, Warnings: 0 I need to research how to mix VHDL and Verilog for modelsim. I will add this task to my work queue. Thanks for your help. Ben
