BMart12
6 years agoWhere or how can I get import mgc_axi_pkg::* ?
Hello, I am using Quartus Prime 18.1.0 Standard Edition and ModelSim - Intel Starter Edition 10.5b. I am trying to simulate an HPS design I made on Platform Designer. The macro file fails to load b...
AnilErinch_A_Intel
6 years agoHi ,
If you check the mgc_common_axi.sv , you should be seeing the package.
package mgc_axi_pkg;
Please check why it is not getting imported , please refer the system verilog guidelines and the scripts which are being used to debug the same.
Thanks and Regards
Anil
BMart12
6 years agoHi Anil,
Below is the list of the files in the folder that contains mgc_axi* files. As you see, mgc_axi_pkg is missing. I edited the source file that is importing mgc_axi_pkg.sv to import mgc_axi_bfm_pkg.vhd. I encountered errors due to VHDL differences with Verilog. I am letting go of trying to simulate soc_system. You can close this case unless you can provide me with the missing package.
Thanks for your help.
Ben
Volume in drive C is OS
Volume Serial Number is 0AFB-B554
Directory of C:\intelFPGA_lite\18.1\ip\altera\mentor_vip_ae\axi3\bfm
06/16/2020 12:09 PM <DIR> .
06/16/2020 12:09 PM <DIR> ..
06/16/2020 12:09 PM 0 mgc.lst
02/20/2019 04:09 AM 290,692 mgc_axi_bfm_pkg.vhd
02/20/2019 04:09 AM 382 mgc_axi_inline_monitor.mti.svp
02/20/2019 04:09 AM 7,727 mgc_axi_inline_monitor.sv
02/20/2019 04:09 AM 13,034 mgc_axi_inline_monitor.vhd
02/20/2019 04:09 AM 14,996 mgc_axi_inline_monitor_hw.tcl
02/20/2019 04:09 AM 507 mgc_axi_master.mti.svp
02/20/2019 04:09 AM 100,722 mgc_axi_master.sv
02/20/2019 04:09 AM 28,778 mgc_axi_master.vhd
02/20/2019 04:09 AM 10,729 mgc_axi_master_hw.tcl
02/20/2019 04:09 AM 505 mgc_axi_monitor.mti.svp
02/20/2019 04:09 AM 96,028 mgc_axi_monitor.sv
02/20/2019 04:09 AM 34,501 mgc_axi_monitor.vhd
02/20/2019 04:09 AM 505 mgc_axi_slave.mti.svp
02/20/2019 04:09 AM 118,731 mgc_axi_slave.sv
02/20/2019 04:09 AM 34,681 mgc_axi_slave.vhd
02/20/2019 04:09 AM 11,648 mgc_axi_slave_hw.tcl
02/20/2019 04:09 AM 1,674,282 mgc_common_axi.sv
18 File(s) 2,438,448 bytes
2 Dir(s) 366,858,219,520 bytes free
