Unexpected behaviour of DDR3 SDRAM ready and data_valid signals
@sstrell one more thing I want to add here, Whatever you said makes sense but frequency is also playing role here.
The external memory interface width is 32 bits, but it is DDR running at 300 MHZ.
So at 300MHZ we are getting 64 bits and as AFI clock is 150 MHZ, we should get 128 bits per clock cycle.
Now my design is running at 50 MHZ with a interconnect IP in between, connecting SDRAM and MY IP.
In that case also I should get continuous data and VALID/READY signal.
This is my understanding, please correct me if I am wrong.
AFI clock is 150Mhz and user design is running 50Mhz, I presume there is avalon MM clock crossing bridge as interconnect between AFI and user clock. Can you check how many burst counts is set in the interconnect ? If that is set only one you should change to 4 or more.
- Yogesh5 years ago
Yes there is a Interconnect IP, which QSYS puts by default but there is no option to control burst length in that.
But there is a option of "Maximum Burst Length" in SDRAM IP, which is by default set to 4 in SDRAM IP -> controller settings. (Please find attached screenshot of the same)
As per the External Memory Interface Handbook Volume 2:
Page - 328 says that this "Maximum Burst Length" parameter affects the FIFO parameters in Interconnect.
We tried changing it from 4 to 128, still can't see any improvement.
Can you suggest what may be going wrong, which can explain why each transaction in a burst is taking 3 clock cycles, so a burst length of 256 is eventually taking 256*3 = 768 clock cycles.
- yoichiK_altera5 years ago
Contributor
Can you replace the interconnect IP to Avalong-MM Clock Crossing Bridge IP from current one ? By default qsys insert interconnect IP without FiFo and burst read/write will be chopped in the interconnect IP.
- Yogesh5 years ago
I am not able to find the option of replacing the interconnect IP with the Avalon-MM Clock Crossing Bridge IP, can you suggest how to do that?
Instead of this, I tried changing the option Adaptor types in Interconnect requirements from Handshake to FIFO(Please check the attached screenshot).
The problem is now I can't see the trigger on STP which I could in case of Adaptor type is - Handshake.
And if I can't see the STP then it is difficult to see the pattern of Rvalid and Wready signal, so can you please help me in this scenario?
