13 years agoStratix V GX SI Dev Kit - Sometimes no link in Transceiver Toolkit
i am using the mentioned board and successfully tested an external transceiver loop with the examples (10312 mbps). I also changed the phy in qsys to fractions of 10312 mbps whichs works as long as the reference clock remains constant. Now I changed to 6000 mbps with 300 MHz and i get no link, also 12500 mbps with 500 MHz refclk. In another case I configured the low latency PHY with 8000mbps and 500 MHz and it works without problems. I changed the refclk to 500 MHz in Qsys/clocks, Qsys/phy and in the sdc-file and of cause i changed the clock on the board. Does anyone has an idea why some datarates doesn't work, respectivly what I forgot? Thanks, Micha4 Replies
It sound weird, the higher rate works fine while lower rate seems problematic. You mentoned it does not work in external loopbavk, how about internal loopback?
Question: thd first attempt is work on custom phy or native phy? can try the non-working rate on low latency phy as seem low latency phy is alqays working? - Altera_Forum
--- Quote Start --- It sound weird, the higher rate works fine while lower rate seems problematic. You mentoned it does not work in external loopbavk, how about internal loopback? --- Quote End --- i will take a look. --- Quote Start --- Question: thd first attempt is work on custom phy or native phy? can try the non-working rate on low latency phy as seem low latency phy is alqays working? --- Quote End --- All rates are made on low latency phy. So, I can't follow you exactly, can you give me some more explainations :)? - Altera_Forum
Ok, if all on low latency phy, then it is fine. I though u try on different phy. I am trying to isolate the common failure symptom from your experiments
Maybe u can try the 6gbps using Native Phy, to isolate whether is phy dependent.
