13 years agoStratix V GX SI Dev Kit - Sometimes no link in Transceiver Toolkit
Hello, i am using the mentioned board and successfully tested an external transceiver loop with the examples (10312 mbps). I also changed the phy in qsys to fractions of 10312 mbps whichs works as...
13 years ago --- Quote Start --- It sound weird, the higher rate works fine while lower rate seems problematic. You mentoned it does not work in external loopbavk, how about internal loopback? --- Quote End --- i will take a look. --- Quote Start --- Question: thd first attempt is work on custom phy or native phy? can try the non-working rate on low latency phy as seem low latency phy is alqays working? --- Quote End --- All rates are made on low latency phy. So, I can't follow you exactly, can you give me some more explainations :)?
