13 years agoStratix V GX SI Dev Kit - Sometimes no link in Transceiver Toolkit
Hello, i am using the mentioned board and successfully tested an external transceiver loop with the examples (10312 mbps). I also changed the phy in qsys to fractions of 10312 mbps whichs works as...
13 years agoIt sound weird, the higher rate works fine while lower rate seems problematic. You mentoned it does not work in external loopbavk, how about internal loopback?
Question: thd first attempt is work on custom phy or native phy? can try the non-working rate on low latency phy as seem low latency phy is alqays working?
