PedroJServian
1 year agoProblems with DEV_CLRN and PINs, MAX10
Hi colleagues, I have been dealing with a problem with a design I have made for my 10M08 FPGA. My program have a "PWM treatment" design that gets some PWM signals from a microcontroller and makes a ...
FvM
1 year agoWhen DEV_CLRn isn't used in your design, you should disable global device clear function in Device & Pin settings. If you already did, your issues can't be related to DEV_CLRn level.
Problems at startup may be caused by weak-pullup of FPGA IO pins in unconfigured state that cause a high level during start-up if no external pull-down resistors of sufficient strength are connected.
