gustifix2
2 years agoOneAPI for Agilex 7 I-Series Dev Kit: build-default-binaries.sh fails
Hello!
I am following https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/ to set up OneAPI for the Agilex 7 I-Series Development Kit (2x R-Tile, 1x F-Tile).
At step 2.5.1 Compile Initialization Bitstreams the command
./build-default-binaries.sh -b ofs_iseries-dk
failed with the output in the attached file.
Regarding the Verilog error, I found this https://www.intel.in/content/www/in/en/programmable/quartushelp/22.1/index.htm#msgs/msgs/evrfx2_veri_opposite_direction.htm. Is there actually an error in ofs_plat_prim_burstcount1_mapping_gearbox.sv or am I doing something wrong?
All tools should be the versions mentioned in the OneAPI ASP Getting Started Guide but the host OS is Ubuntu 24.04.
I would appreciate some help. Thanks!
Felix
