gustifix2
1 year agoOneAPI for Agilex 7 I-Series Dev Kit: build-default-binaries.sh fails
Hello! I am following https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/ to set up OneAPI for the Agilex 7 I-Series Development Kit (2x R-Tile, 1x F-Tile). At step 2...
gustifix2
1 year agoThank you for all the help so far! With the new build_top.sh command the compile succeeded.
I continued the guide until section 2.5.3, where aocl diagnose succeeds but aocl diagnose acl0 fails. I attached the output of both commands.
I will try compiling the original FIM without my modifications to the DDR config again but use the new build_top.sh command and report back if it changes anything.
Best wishes
Felix
gustifix2
1 year agoOK, I tried it again with the unmodified FIM and got the same error from aocl diagnose acl0.
I also tried continuing the guide and built the board_test.fpga binary. It results in a similar error (attached file).
- gustifix21 year ago
I also tried running the simple-add and vector-add from oneAPI-samples, but they just show
Running on device: ofs_iseries-dk : Intel OFS Platform (ofs_ea00000) Vector size: 10000and nothing happens afterwards.
