ymiler's avatar
ymiler
2 years ago
ODDR clock
I need to create a source synchronous connection between two FPGAs.
FPGA A needs to transmit 32 data bits with a clock to FPGA B.
All 32 bits are sampled by a PLL clock and then sent to 32 IO_OBUF pins. The same PLL clock (which samples the 32 data bits) is connected to another IO_OBUF.
I would like to align the clock and the 32 data bits to the same flip-flop delay value.
Is there an IP core or an alternative method to create an ODDR that is sampled by the PLL clock and generates a new clock that is aligned with the flip-flop for the 32 data bits?
Thank you!
  • Hi,
    there's probably no advantage by using GPIO. A behavioral or structural description of the output logic will most likely end up in a similar or identical hardware implementation. I mentioned GPIO because you asked.
    Also your existing SDC specification should work.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    • ymiler's avatar
      ymiler
      My device is Stratix 10,
      My Quartus version is Quartus Prime Pro Edition 22.3
      I don't find ALTDDIO IP in this version, maybe there is other IP which relevant to my version / device?
  • FvM's avatar
    FvM
    in Quartus Pro, ODDR and IDDR functions are contained in GPIO Intel IP.
    • ymiler's avatar
      ymiler
      OK ,
      I have several Q
      1)Currently , my SDC file include definition of the PLL clock and input & output delay to the data output ports
      Should I change the constraints since I add GPIO IP which get the PLL clock as input ?
      2)Should I expect better result with the GPIO IP ?
  • FvM's avatar
    FvM
    AqidAyman_Altera
    I wish to follow up. Do you have more questions or support needed?
