ymiler
Contributor
2 years agoODDR clock
Hi, I need to create a source synchronous connection between two FPGAs. FPGA A needs to transmit 32 data bits with a clock to FPGA B. All 32 bits are sampled by a PLL clock and then sent to 32 IO_...
- 1 year ago
there's probably no advantage by using GPIO. A behavioral or structural description of the output logic will most likely end up in a similar or identical hardware implementation. I mentioned GPIO because you asked.
Also your existing SDC specification should work.
FvM
1 year agoHi,
in Quartus Pro, ODDR and IDDR functions are contained in GPIO Intel IP.
- ymiler1 year ago
Contributor
OK ,
I have several Q
1)Currently , my SDC file include definition of the PLL clock and input & output delay to the data output ports
Should I change the constraints since I add GPIO IP which get the PLL clock as input ?
2)Should I expect better result with the GPIO IP ?
