SLB-Aman_Arab's avatar
SLB-Aman_Arab
1 year ago
Need PCB land pattern for part EP4CE6F17C8N
Hello Team,
Please share the recommended land pattern for part EP4CE6F17C8N.
Aman Arab
  • Farabi_Altera's avatar
    Farabi_Altera
    Hi Aman,
    Please refer to attached package drawing for land pattern recommendation. link : https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/packaging/04R00230-03.pdf
    FBGA-256 Ball Grid Array- 0.8mm pitch
    Ball pitch = 0.8mm
    Pad(Land) Diameter = 0.3mm to 0.35mm
    Solder Mask Opening = 0.4mm
    Pad Type = NSMD (Non-Solder Mask Defined) recommended
    NSMD Pad size = 0.30mm to 0.33mm diameter
    Solder Mask Clearance = +0.05mm all around pad
    Package size = 17mm x 17mm
    regards,
    Farabi
    • SLB-Aman_Arab's avatar
      SLB-Aman_Arab
      Hello Farabi,
      Thank you for your response. We kindly request the pin numbering details from pin 1 to pin 256, along with the corresponding pin functions/significance for each. This information is essential for our analysis and proper integration. The details you shared are helpful in understanding the footprint only.
      Aman Arab
        SLB-Aman_Arab
        Hello Team,
        Any updates on the requested PINs details?
        Aman Arab
