Need PCB land pattern for part EP4CE6F17C8N
- 1 year agoBGA pin numbering is alphanumerical (A1..A16, B1..) etc., it's specified in above linked package drawing, please review.
Pinout is described in separate documents, browse https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html
Hi Aman,
Please refer to attached package drawing for land pattern recommendation. link : https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/packaging/04R00230-03.pdf
FBGA-256 Ball Grid Array- 0.8mm pitch
Ball pitch = 0.8mm
Pad(Land) Diameter = 0.3mm to 0.35mm
Solder Mask Opening = 0.4mm
Pad Type = NSMD (Non-Solder Mask Defined) recommended
NSMD Pad size = 0.30mm to 0.33mm diameter
Solder Mask Clearance = +0.05mm all around pad
Package size = 17mm x 17mm
regards,
Farabi
Hello Farabi,
Thank you for your response. We kindly request the pin numbering details from pin 1 to pin 256, along with the corresponding pin functions/significance for each. This information is essential for our analysis and proper integration. The details you shared are helpful in understanding the footprint only.
Aman Arab
- SLB-Aman_Arab1 year ago
Hello Team,
Any updates on the requested PINs details?
Aman Arab
- FvM1 year ago
