NCONT ERROR in ACK for access 0 : ACK = 0x01 in ARM DS
Hi team,
In our custom board, we use AGFB014R24B_3 FPGA SoC. The program is stuck at clock initialization when I run the u-boot-spl using ARM DS. Further, I step into the clock initialization function it is stuck at the cm_wait_for_lock() function. But the HPS clock crystal oscillator is fine.
When I comment on the cm_wait_for_lock() function, it throws an error "NCONT ERROR in ACK for access 0: ACK = 0x01. I don't know why this error came. If something is wrong in the program or some external facts It will go into Exception right, Why will it throw this error?
Veerappan P.
- Jeet14
For your custom board, I hope you have re-generated the u-boot files as mentioned on below link-
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Build_U_45Boot
Also, please check the HPS EOSC frequency configured in HPS and u-boot.dtsi file.
Tiwari
- Veerappan
In socfpga_agilex_socdk.dts the HPS EOSC frequency is 25MHz.
soc {
clocks {
osc1 {
clock-frequency = <25000000>;
};Thanks,
Veerappan P.
- Jeet14
I hope you have re-generated the uboot and u-boot-spl-dtb.hex files.
Also made the necessary changes in the socfpga_agilex_socdk-u-boot.dtsi file w.r.t. your custom design.
Please refer below link to generate the uboot.
Tiwari
- Jeet14
Let me know if you have any question on this.
Tiwari
- Jeet14
