Manik's avatar
Manik
3 years ago
Measuring Temperature through Stratix 10 DX
Hi Intel Community Members,
In the Stratix 10 DX, I wish to have the following clarification
1. How to read temperature values from max6581?
2. Address for reading the registers of max6581 from nios II through I2C IPcore? (Is it 0x4D or 0X9A?)
3. How to convert the temperature hex value to real temperature value in Celsius or Fahrenheit?
4. are the register address given in the max6581 datasheet should be considered as offset?
5. Is there any reference design to read temperature values from intel of similar kind ?
Kindly support me.
Your comments are more valuable to me and highly appreciated.
Thank you
  • Manik's avatar
    Manik
    Please share your suggestions and ideas to get the above things done.
    • Manik's avatar
      Manik
      Hi @Farabi ,
      Alright, Thanks for the response.
      I have gone through the video it is about temperature sensor and value conversion. Really a good material which gave me an idea for my query number 3.
      But, I wish to do it through Intel I2C host IPcore. In the shared video it was directly read by the temp sense IP.
      FYKI, I wish to have access to max6581 which is there in the Stratix 10 DX evaluation board using I2C host ip core in qsys through writing application program which uses the API calls of the I2C host IP.
      Please refer my previous posts (specifically, Dated :10-03-2023 02:09 PM) for the detailed description and required documents.
      Kindly share me some reference designs also along with the fix.
      Thank you
    • Manik's avatar
      Manik
      Yes, still it is open.
      Didn't get any specific fix with I2C host IP core.
      Please do support me.
      Thank you
