10 years agoMax 10 Dev Kit DDR3 Singal Integrity Testing
Is there a way to test DDR3 signal integrity on the Max 10 dev kit? I'm wondering if these signals are accessible anywhere.
You can try to run signal integrity simulation with the IO models ie IBIS and Hspice.
Check out the following links for the Max 10 IO models:
IBIS model - www.altera.com/support/support-resources/download/board-layout-test/ibis/ibs-ibis_index.html Hspice model - www.altera.com/support/support-resources/download/board-layout-test/hspice.html - Altera_Forum
--- Quote Start --- Is there a way to test DDR3 signal integrity on the Max 10 dev kit? I'm wondering if these signals are accessible anywhere. --- Quote End --- Mind further elaborate on the signal integrity that you would like to test? Is it that you are trying to measure the eye?
