KITRON_29_LIFECYCLE STATUS_ROHS_REACH_
Hello, |
I am Donald from TechAdvance Solutions. |
We are contracted by KITRON, to assist them in obtaining the subject data for the parts supplied by you. Please find the attached LOA from your Customer authorizing the same. |
The attached spreadsheet lists the parts supplied by you, for which the Customer is seeking the subject information. The cells which are blank are the ones which we are unable to get the information from your website. |
Kindly provide the below for the attached part list : |
Lifecycle Status : (Active/Obsolete/EOL/NRND) |
Last Time Buy (LTB) date ( If the input part is EOL ) |
RoHS 3 (2015/863/EU) Certificate of Compliance (URL/File Name) |
Alternate RoHS Compliant part if the input part is Obsolete/EOL/NRND/Non-RoHS |
REACH 235 SVHC certificate of Compliance (URL/File Name) |
SCIP reference number for SVHC present parts |
Feel free to contact me for any clarifications/ information. |
Thank you in advance. |
Regards, |
Donald |
Sourcing Engineer |
TechAdvance Solutions |
- BoonBengT_Altera
Moderator
Hi @TechAdvance,
Thank you for posting in Intel community forum and hope all is well.
To clarify further on the request, what Intel specific are you looking at?
Is this FPGA related?
Best Wishes
BB
- BoonBengT_Altera
Moderator
Hi @TechAdvance,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
- TechAdvance
Hello BB,
Yes. Please find the attached documents regarding our request.
Kindly let me know if you have any questions.
Donald.
- BoonBengT_Altera
Moderator
Hi @TechAdvance,
Noted on the situation and request for the fpga parts life cycle status.
We are getting in touch with the relevant teams with the required information and will get back to you at earliest.
Thank you for the patients.
Best Wishes
BB
- NazrulNaim_Intel
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your request and allow me some time to look into your request. I shall come back to you with the information needed.
Thank you for your patience.
Nazrul Naim
- NazrulNaim_Intel
Sorry for the delay. Below I will attach the Excel file for the information needed. As for the highlighted device MPN, can you please confirm back the MPN because the ones that are been highlighted cannot be found in our database.
As for the ROHS information, it can be obtained through the link that I will provide below.
Link : Material Declaration Data Sheets (MDDS) (intel.com)
Do let me know if you need further assistance regarding this request.
Nazrul Naim
- TechAdvance
Hello Nazrul,
Thank you for your email and information. I will check internally and get back to you.
Have a nice day!!.
Donald.- TechAdvance
Hello Nazrul,
Good day. Please find the below feedback from my tech team and do the needful.
"We were unable to get information for the below parts in the MDDS link, Please provide."
KITRON Part Number
Description
MFR
MPN
4102065
IC FPGA ARRIA 220K CELLS 344 I/O FBGA780
INTEL
10AS022E5F29I3SG
4092796
IC FPGA 396 I/O 10AX066K2F35 1152FCBGA
INTEL
10AX066K2F35I2SGES
4088004
IC FPGA ARRIA 10 ES2 1.0V BGA1152
INTEL
10AX115H2F34I2SGE2
4117195
IC FPGA
INTEL
10CX085YU484E6
4071233
IC FPGA 5SGXA3 BGA1517
INTEL
5SGXMA3K3F40CN
4007664
CABLAGE PARALLEL PORT DOWNLOAD CABLE
INTEL
Byteblaster MV parallelport DL
4129635
IC FPGA PLCC44
INTEL
EP1800ILC-70
4128651
IC EP1810 EPLD EPROM
INTEL
EP1810LC-35T
4033562
IC PLD EP1810LC 45NS PLCC
INTEL
EP1810LC-45
4048066
IC PAL 85C220 DIL20
INTEL
EP220DI
4129020
FPGA EP3C10F256C8
INTEL
EP310F256C8
4044728
IC FPGA EP4S40G2F40I2N BGA1517
INTEL
EP4S40G2F40I2NGB
4129829
IC FPGA PLCC28
INTEL
EP610PC-25
4129829
IC FPGA PLCC28
INTEL
EP610PC-30
4002922
IC EPLD EP910ILC 15NS PLCC44
INTEL
EP910ILC-15
4129151
IC PAL LOGIC CMOS PLCC44
INTEL
EP910LC-35
4033575
IC EPLD EP910LI 35NS OTP PLCC
INTEL
EP910LI-35
4003222
IC EPLD EP910PC 30NS DIL40
INTEL
EP910PC-30
4003760
IC EPROM 16MHZ EPC16 BGA88
INTEL
EPC16U88
4121183
IC CONFIG DEVICE 1MBIT 8SOIC
INTEL
EPCS1SC8
4034334
IC EPLD EPF10K10ATC100-2 TQFP
INTEL
EPF10K10ATC100-2N
4121189
IC FPGA 185 I/O INTEL 240QFP
INTEL
EPIC6Q240C8N
4129281
IC EPLD, BLANK
INTEL
EPM5130LC
4124543
IC PROGRAMMABLE LOGIC DEVICE
INTEL
EPM7032JC44-3
4120919
IC FPGA EEPROM 512K 8DIP, BLANK
INTEL
F2341
Donald.
- NazrulNaim_Intel
Hi Donald,
Thank you for the update. Allow me some time to obtain all the information needed as you requested.
Nazrul Naim
- NazrulNaim_Intel
I'm sorry for the delay. Below are the details of information as requested. For your information, most of these devices are either Obsolete/EOL and the sources for these devices are really limited.
10AS022E5F29I3SG - This part number is invalid in Intel Database
10AX066K2F35I2SGES - https://cdrdv2.intel.com/v1/dl/getContent/691990?fileName=10AX066K2F35I2SG_20191127095238_v1.xml
10AX115H2F34I2SGE2 - https://cdrdv2.intel.com/v1/dl/getContent/692862?fileName=10AX115H2F34I2SG_20191127165824_v1.xml
10CX085YU484E6 - This part number is invalid in Intel Database
5SGXMA3K3F40CN - This part number is invalid in Intel Database
Byteblaster MV parallelport DL - No MDDS available
EP1800ILC-70 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-35T - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-45 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP220DI - https://cdrdv2.intel.com/v1/dl/getContent/677856?explicitVersion=true&fileName=pdn9508.pdf
EP310F256C8 - This part number is invalid in Intel Database
EP4S40G2F40I2NGB - https://cdrdv2.intel.com/v1/dl/getContent/701889?fileName=EP4S40G2F40I2N_20191201044322_v1.xml
EP610PC-25 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP610PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910ILC-15 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LC-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LI-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EPC16U88 - Does not have MDDS
EPCS1SC8 - Please kindly note that the Intel® Enpirion® Power Product family is obsolete per Product
Discontinuance Notice PDN2133.With this obsolescence, we no longer retain Enpirion design, applications, testing, or failure
analysis capabilities and are unable to provide failure analysis services for Enpirion products.
EPF10K10ATC100-2N - https://cdrdv2.intel.com/v1/dl/getContent/699140?fileName=EPF10K10ATC100-2_20191201105555_v1.xml
EPIC6Q240C8N - This part number is invalid in Intel Database
EPM5130LC - Does not have MDDS
EPM7032JC44-3 - This part number is invalid in Intel Database
F2341 - This part number is invalid in Intel Database
Hope this answers your question.
Nazrul Naim
- NazrulNaim_Intel
Nazrul Naim
