KITRON_29_LIFECYCLE STATUS_ROHS_REACH_
I'm sorry for the delay. Below are the details of information as requested. For your information, most of these devices are either Obsolete/EOL and the sources for these devices are really limited.
10AS022E5F29I3SG - This part number is invalid in Intel Database
10AX066K2F35I2SGES - https://cdrdv2.intel.com/v1/dl/getContent/691990?fileName=10AX066K2F35I2SG_20191127095238_v1.xml
10AX115H2F34I2SGE2 - https://cdrdv2.intel.com/v1/dl/getContent/692862?fileName=10AX115H2F34I2SG_20191127165824_v1.xml
10CX085YU484E6 - This part number is invalid in Intel Database
5SGXMA3K3F40CN - This part number is invalid in Intel Database
Byteblaster MV parallelport DL - No MDDS available
EP1800ILC-70 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-35T - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP1810LC-45 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP220DI - https://cdrdv2.intel.com/v1/dl/getContent/677856?explicitVersion=true&fileName=pdn9508.pdf
EP310F256C8 - This part number is invalid in Intel Database
EP4S40G2F40I2NGB - https://cdrdv2.intel.com/v1/dl/getContent/701889?fileName=EP4S40G2F40I2N_20191201044322_v1.xml
EP610PC-25 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP610PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910ILC-15 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LC-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910LI-35 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EP910PC-30 - https://cdrdv2.intel.com/v1/dl/getContent/677809?explicitVersion=true&fileName=pdn0605.pdf
EPC16U88 - Does not have MDDS
EPCS1SC8 - Please kindly note that the Intel® Enpirion® Power Product family is obsolete per Product
Discontinuance Notice PDN2133.With this obsolescence, we no longer retain Enpirion design, applications, testing, or failure
analysis capabilities and are unable to provide failure analysis services for Enpirion products.
EPF10K10ATC100-2N - https://cdrdv2.intel.com/v1/dl/getContent/699140?fileName=EPF10K10ATC100-2_20191201105555_v1.xml
EPIC6Q240C8N - This part number is invalid in Intel Database
EPM5130LC - Does not have MDDS
EPM7032JC44-3 - This part number is invalid in Intel Database
F2341 - This part number is invalid in Intel Database
Hope this answers your question.
Nazrul Naim
