danield17
7 months agoJTAG Chain Broken – Unable to Program Agilex 5 Modular Development Board
I recently started working with the Agilex 5 Modular Development Board, and it suddenly can no longer be programmed.
The USB cable in use is known to be working.
When I connect the cable, it is detected, but when I run the “Auto Detect” option in the Quartus Programmer, I receive the following message:
When running the JTAG Chain Test, I see the following result:
I also tried using the Configuration Debugger, but when I attempt to select the hardware cable, I encounter Error code 87:
I would appreciate any help in resolving this issue, and I can provide additional details or logs if needed.
