8 years ago
Implementing adc on cyclone 5
implemented the module according to manual i was able to run the program successfully but i am not able to find the output
may be i assigned the pins in wrong way can anyone suggest me to which pin i should assign the following adc_sclk and adc saddr , adc cs and adc sdat
thank you
    successfully done with ADC part!!
    i have one more question is it possible to read a analog output on GPIO by connecting additional circuitary (DAC)
    for example i want to apply analog signal on 2*5 adc header and read that on GPIO
    is it possible?
    thank you
    Mahesh
    --- Quote Start ---
    is it possible?
    thank you
    Mahesh
    --- Quote End ---
    Yes, you can use additional circuitry.
    While selecting DAC circuitry take care on LSB/Resolution of DAC and GPIO capability.(i.e Whether you can detect the LSB change?)
    Anand Raj Shankar
    is there any example related to this where i can understand something and implement ?
    and i am planning to use ic ad421 which is a dac ( external circuit )to convert digital signal on gpio to analog
    ADC IS 12BIT resolution which is inbuilt so
    reading an input signal on 2*5 header is done !
    how can i read the same analog signal on GPIO?
    just similar to connecting to leds on board ?
    or there is any other technique
    or should i use pwm?
    if there are any example it will help me alot
    1.You should have DAC resolution of at least 12 or greater is better keeping verf in consideration and also the driving strength.
    2.Chose a board/Design like that, You can find the some martials from terasic for other board/daughter boards which will help you to understand requirements for your board.
    Check the board below
    http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=278
    https://www.altera.com/content/dam/altera-www/global/en_us/portal/dsn/42/doc-us-dsnbk-42-5008051605255-d8m-gpio-user-manual.pdf
    Anand Raj Shankar
