8 years agoImplementing adc on cyclone 5
implemented the module according to manual i was able to run the program successfully but i am not able to find the output may be i assigned the pins in wrong way can anyone suggest me to which pi...
8 years agoADC IS 12BIT resolution which is inbuilt so
reading an input signal on 2*5 header is done ! how can i read the same analog signal on GPIO? just similar to connecting to leds on board ? or there is any other technique or should i use pwm? if there are any example it will help me alot
