8 years agoImplementing adc on cyclone 5
implemented the module according to manual i was able to run the program successfully but i am not able to find the output may be i assigned the pins in wrong way can anyone suggest me to which pi...
8 years agoHi,
1.You should have DAC resolution of at least 12 or greater is better keeping verf in consideration and also the driving strength. 2.Chose a board/Design like that, You can find the some martials from terasic for other board/daughter boards which will help you to understand requirements for your board. Check the board below http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=278 https://www.altera.com/content/dam/altera-www/global/en_us/portal/dsn/42/doc-us-dsnbk-42-5008051605255-d8m-gpio-user-manual.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
