// ADXL clock= 500,000samples of 50Mhz/100Hz
// ADXL address= 0x1D/11101 (alt address pin grounded)
module ADXL_Read(clk_50, I2C_sclk, I2C_sdat, key0, key1, clk_st, data1);
input clk_50;
output I2C_sclk;
output data1;
inout I2C_sdat;
input key0; //Trigger0 to reset
input key1; //Trigger1 to begin
output clk_st;
reg [30:0] a;
reg [30:0] b;
reg clk; //Clk for slave
reg clk_signaltap; //Clk for signaltap2
reg q; //Register for Trigger
reg [10:0] step;
reg [6:0] sl_ad = 7'b0011101; // Slave Address
reg [7:0] reg_ad = 8'h2D; // Register Address
reg [7:0] data1; // Databyte#1
reg sclk;
reg sdat;
initial begin
step = 0;
q = 0;
end
always @(posedge clk_50)
begin
if(a == 1000000) //Clock for Slave with sample 2a
begin
clk = ~clk;
a = 1;
end
else
a = a + 1;
//Signaltap begin
if(b == 500000) //Clock for Signaltap2
begin
clk_signaltap = ~clk_signaltap;
b = 1;
end
else
b = b + 1;
end
//Signaltap end
always @(posedge clk_50) //Trigger Condition
case({!key1, !key0}) //Active low
2'b00 : q <= q;
2'b10 : q <= 1; //Set
2'b01 : q <= 0; //Reset
endcase
always @(posedge clk)
begin
if (q == 1)
begin
case(step)
//Initial
0: begin sclk = 1; sdat = 1; step = 1; end
//1.Start
1: begin sclk = 1; sdat = 0; step = 2; end
2: begin sclk = 0; sdat = 0; step = 3; end
//2.Slave add
3: begin sclk = 0; sdat = sl_ad[6]; step = 4; end
4: begin sclk = 1; sdat = sl_ad[6]; step = 5; end
5: begin sclk = 0; sdat = sl_ad[5]; step = 6; end
6: begin sclk = 1; sdat = sl_ad[5]; step = 7; end
7: begin sclk = 0; sdat = sl_ad[4]; step = 8; end
8: begin sclk = 1; sdat = sl_ad[4]; step = 9; end
9: begin sclk = 0; sdat = sl_ad[3]; step = 10; end
10: begin sclk =1; sdat = sl_ad[3]; step = 11; end
11: begin sclk = 0; sdat = sl_ad[2]; step = 12; end
12: begin sclk = 1; sdat = sl_ad[2]; step = 13; end
13: begin sclk = 0; sdat = sl_ad[1]; step = 14; end
14: begin sclk = 1; sdat = sl_ad[1]; step = 15; end
15: begin sclk = 0; sdat = sl_ad[0]; step = 16; end
16: begin sclk = 1; sdat = sl_ad[0]; step = 17; end
//3.sdat = 0
17: begin sclk = 0; sdat = 0; step = 18; end
18: begin sclk = 1; sdat = 0; step = 19; end
//4.Acknowledge
19: begin sclk = 0; sdat = 1'bz; step = 20; end
20: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 20; else step = 21; end
//5.Reg add
21: begin sclk = 0; sdat = reg_ad[7]; step = 22; end //7
22: begin sclk = 1; sdat = reg_ad[7]; step = 23; end
23: begin sclk = 0; sdat = reg_ad[6]; step = 24; end //6
24: begin sclk = 1; sdat = reg_ad[6]; step = 25; end
25: begin sclk = 0; sdat = reg_ad[5]; step = 26; end //5
26: begin sclk = 1; sdat = reg_ad[5]; step = 27; end
27: begin sclk = 0; sdat = reg_ad[4]; step = 28; end //4
28: begin sclk = 1; sdat = reg_ad[4]; step = 29; end
29: begin sclk = 0; sdat = reg_ad[3]; step = 30; end //3
30: begin sclk = 1; sdat = reg_ad[3]; step = 31; end
31: begin sclk = 0; sdat = reg_ad[2]; step = 32; end //2
32: begin sclk = 1; sdat = reg_ad[2]; step = 33; end
33: begin sclk = 0; sdat = reg_ad[1]; step = 34; end //1
34: begin sclk = 1; sdat = reg_ad[1]; step = 35; end
35: begin sclk = 0; sdat = reg_ad[0]; step = 36; end //0
36: begin sclk = 1; sdat = reg_ad[0]; step = 37; end
//6.Acknowledge
37: begin sclk = 0; sdat = 1'bz; step = 38; end
38: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 38; else step = 39; end
//7.Start
39: begin sclk = 0; sdat = 0; step = 40; end //sclk= 0, sdat= 0
40: begin sclk = 1; sdat = 1; step = 41; end //sclk= 1, sdat= 1
41: begin sclk = 1; sdat = 0; step = 42; end //sclk= 1, sdat= 0
42: begin sclk = 0; sdat = 0; step = 45; end //sclk= 0, sdat= 0 ---------------
//8.Slave Add
45: begin sclk = 0; sdat = sl_ad[6]; step = 46; end //6
46: begin sclk = 1; sdat = sl_ad[6]; step = 47; end
47: begin sclk = 0; sdat = sl_ad[5]; step = 48; end //5
48: begin sclk = 1; sdat = sl_ad[5]; step = 49; end
49: begin sclk = 0; sdat = sl_ad[4]; step = 50; end //4
50: begin sclk = 1; sdat = sl_ad[4]; step = 51; end
51: begin sclk = 0; sdat = sl_ad[3]; step = 52; end //3
52: begin sclk = 1; sdat = sl_ad[3]; step = 53; end
53: begin sclk = 0; sdat = sl_ad[2]; step = 54; end //2
54: begin sclk = 1; sdat = sl_ad[2]; step = 55; end
55: begin sclk = 0; sdat = sl_ad[1]; step = 56; end //1
56: begin sclk = 1; sdat = sl_ad[1]; step = 57; end
57: begin sclk = 0; sdat = sl_ad[0]; step = 58; end //0
58: begin sclk = 1; sdat = sl_ad[0]; step = 59; end
//9.sdat = 1
59: begin sclk = 0; sdat = 1; step = 60; end
60: begin sclk = 1; sdat = 1; step = 61; end
//10.Acknowledge
61: begin sclk = 0; sdat = 1'bz; step = 62; end
62: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 62; else step = 63; end
//11.Databyte#1
63: begin sclk = 0; sdat = 1'bz; step = 64; end //Databyte#1 bit 7
64: begin sclk = 1; sdat = 1'bz; data1[7] = I2C_sdat; step = 65; end
65: begin sclk = 0; sdat = 1'bz; step = 66; end //6
66: begin sclk = 1; sdat = 1'bz; data1[6] = I2C_sdat; step = 67; end
67: begin sclk = 0; sdat = 1'bz; step = 68; end //5
68: begin sclk = 1; sdat = 1'bz; data1[5] = I2C_sdat; step = 69; end
69: begin sclk = 0; sdat = 1'bz; step = 70; end //4
70: begin sclk = 1; sdat = 1'bz; data1[4] = I2C_sdat; step = 71; end
71: begin sclk = 0; sdat = 1'bz; step = 72; end //3
72: begin sclk = 1; sdat = 1'bz; data1[3] = I2C_sdat; step = 73; end
73: begin sclk = 0; sdat = 1'bz; step = 74; end //2
74: begin sclk = 1; sdat = 1'bz; data1[2] = I2C_sdat; step = 75; end
75: begin sclk = 0; sdat = 1'bz; step = 76; end //1
76: begin sclk = 1; sdat = 1'bz; data1[1] = I2C_sdat; step = 77; end
77: begin sclk = 0; sdat = 1'bz; step = 78; end //0
78: begin sclk = 1; sdat = 1'bz; data1[0] = I2C_sdat; step = 79; end
//12.Acknowledge
79: begin sclk = 0; sdat = 1'bz; step = 80; end
80: begin sclk = 1; sdat = 1'bz; if (I2C_sdat == 1) step = 80; else step = 81; end
//13.Stop
81: begin sclk = 1; sdat = 0; step = 82; end //sclk= 1, sdat= 0
82: begin sclk = 1; sdat = 1; step = 83; end //sclk= 1, sdat= 1
83: begin sclk = 1; sdat = 1; end
endcase
end
end
assign I2C_sclk = sclk;
assign I2C_sdat = sdat;
assign clk_st = clk_signaltap;
endmodule
Now problem's solved.
I also do some modification so that I feed each new data at sdat when the sclk is low(instead of when it was high) and I read the needed data when the sclk is high. That way I could be sure although if there is any delay when the data is being transmited by the slave, I could still get the right data.
Thank you so much Daixiwen. Without your help, I may still stuck in this problem now.
