how to test FPGA PAC N3000 network port
FPGA PAC N3000, configed in 8x10G mode, attached to the Xeron serverA with pcie x16 。we got 40GbE servrB/ 10GbE serverC , QSFP+40G SR-L optical module and 12core mo3 fiber。test case:1) serverA-->one port QSFP and fiber--> serverB: leds out 2)serverA(B)-->one port to another port-->serverA(B);leds on
(a).should we puchase E40GQSFPSR to displace QSFP+40G SR-L? (b)give some advices.
by the way,I didn't enable Vx-Tx Vx-d(not found in the bios),may it help? thanks a lot
- JonWay_altera
Hi @fzhan51 First of all, what is the objective of your test? A simple functionality test? If yes, you can refer to:
Test by DPDK
Test by fpgadiag:
- fzhan51
thank you. we want a simple test fot the connection between n3000 qsfp port and the port of other 40GbE networkcard , a ping test etc. beside,
today,I got empty when entered lspci | grep 0d58 or lspci | grep 0cf8 ,what may cause that?
- JonWay_altera
Is the card alive? Did you connect the AUX cable? Can this recover by reset? Is it overheated?
any status logs e.g. fpgainfo fme? fpgainfo bmc? etc
...i can help more if there is more info.
- fzhan51
the cable is 12core mo3 fiber; we are purchasing X4DACBL3 to try; reset not fix;
I just found that the Image may be upgraded to Production Version for trying the connection, how can I revert it?
we bought a E40GQSFPSR optic mode to test with 12core mo3 fiber and other optic mode,seems no help.
for now,the 40G serverB is not available, i connect the netport QSFPa(QSFP+40G SR-L) to netportQSFPb(QSFP+40G SR-L) with 12core mo3 fiber
[fpga@localhost ~]$sudo fpgainfo fme
Board Management Controller, MAX10 NIOS FW version D.2.0.19
Board Management Controller, MAX10 Build version D.2.0.6
//****** FME ******//
Object Id : 0xF500000
PCIe s:b:d.f : 0000:07:00.0
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Bitstream Id : 0x23000010010309
Bitstream Version : 0.2.3
Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846
Boot Page : user
[fpga@localhost ~]$ sudo fpgainfo phy
[sudo] password for fpga:
//****** PHY ******//
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
//****** PHY GROUP 0 ******//
Direction : Line side
Speed : 10 Gbps
Number of PHYs : 8
//****** PHY GROUP 1 ******//
Direction : Host side
Speed : 10 Gbps
Number of PHYs : 8
//****** Intel C827 Retimer ******//
Port0 10G : Up
Port1 10G : Up
Port2 10G : Up
Port3 10G : Up
Port4 10G : Up
Port5 10G : Up
Port6 10G : Up
Port7 10G : Up
Retimer A Version : 101c.1064
Retimer B Version : 101c.1064
[fpga@localhost ~]$ sudo fpgainfo bmc
//****** BMC SENSORS ******//
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
( 1) Board Power : 69.56 Watts
( 2) 12V Backplane Current : 3.20 Amps
( 3) 12V Backplane Voltage : 12.15 Volts
( 4) 1.2V Voltage : 1.18 Volts
( 6) 1.8V Voltage : 1.80 Volts
( 8) 3.3V Voltage : 3.25 Volts
(10) FPGA Core Voltage : 0.90 Volts
(11) FPGA Core Current : 15.07 Amps
(12) FPGA Die Temperature : 69.00 Celsius
(13) Board Temperature : 43.50 Celsius
(14) QSFP0 Supply Voltage : 3.27 Volts
(15) QSFP0 Temperature : 51.00 Celsius
(24) 12V AUX Current : 2.53 Amps
(25) 12V AUX Voltage : 12.11 Volts
(37) QSFP1 Supply Voltage : 3.27 Volts
(38) QSFP1 Temperature : 54.00 Celsius
(44) PKVL0 Core Temperature : 68.00 Celsius
(45) PKVL0 SerDes Temperature : 68.50 Celsius
(46) PKVL1 Core Temperature : 69.00 Celsius
(47) PKVL1 SerDes Temperature : 69.50 Celsius
how to test the connection in this case ,and how to check tx and rx ?
- fzhan51
for above connection ,if disconnect the fiber
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Speed : 10 Gbps
Number of PHYs : 8
Speed : 10 Gbps
Number of PHYs : 8
Port0 10G : Down
Port1 10G : Down
Port2 10G : Down
Port3 10G : Down
Port4 10G : Down
Port5 10G : Up
Port6 10G : Up
Port7 10G : Down
why Port5/Port6 always Up ?
- JonWay_altera
Hi @fzhan51 Lets take a step back. So i suppose you are able to see output from lspci | grep ocf8, right?
Let me get to your last question... If you have removed all the cable, i would expect port 5/6 to be "Down"...
Could you try "rsu bmcimg <BDF>" and run fpgainfo phy again to see if that recovers the card?
- JonWay_altera
So, you still cant see 0CF8?
Then, lets fix this first.
I know you have provided some info, but could you fill up some basic info as below (if too long, then put in a text file and attach it here). Thanks.
Operating System Vendor and Version
Kernel Version
Server Vendor and Model
Intel Acceleration Stack release i.e. Beta, Production
Ethernet Port Configuration i.e 2x2x25G, 4x25G, 8x10G
I40e and iavf driver version
I40e and iavf firmware version
log or screenshot of fpgainfo fme, fpgainfo bmc, fpgainfo phy, fpgainfo errors
dmesg log file
lspci -vvv log file
Run "lspci -vt"
and also lspci | grep Ethernet
- fzhan51
Dear JwChin:
[3days ago,the system installed by others]
Operating System Vendor and Version: linux-4.19.8
Kernel Version: 4.19.8
rpm -qa | grep kernel-header: kernel-headers-3.10.0-1062.18.1.el7.x86_64
Server Vendor and Model: HUAWEI/H22H-03
Intel Acceleration Stack release i.e. Beta, Production: IntelAccelerationStack release.jpg Alpha-1 D.1.0.13
Ethernet Port Configuration i.e 2x2x25G, 4x25G, 8x10G: 8x10G
I40e and iavf driver version: i40e-2.9.21
I40e and iavf firmware version: iavf-3.7.53
[now]
Operating System Vendor and Version: CentOS-7-x86_64-Everything-1611.iso(maybe)
Kernel Version: 3.10.0-1062.18.1.el7.x86_64
Intel Acceleration Stack release i.e. Beta, Production: Production D.2.0.6
I40e and iavf driver version: i40e-2.10.19.30(i40e-2.9.21 compiled failed)
I40e and iavf firmware version: iavf-3.7.61.20(when install,it says invalid private key)
maybe there were some mistakes when I did OTSU/RSU
- JonWay_altera
hi @fzhan51 It doesnt seems right that 0CF8 DID is not showing.
From experience, it could be the kernel (im using 3.10.0-957.el7.x86_64). Second, it could be the OTSU/RSU.
If it were me, I would probably check the correct OS and kernel version and to perform the OTSU/RSU again....might be a long-winded process but at least you can watch for any error and foolproof it.
- fzhan51
Dear JwChin: reinstall Centos 7.6 does help,0cf8 shows correctly.thank you very much .
- JonWay_altera
Hi @fzhan51 Thank you for your update. So, it might be something wrong with the kernel, and it resolved over re-installing. This is great input for others watching the forum, thanks.
